Old 10-21-2014, 12:35 PM   #1
mheffel
Drives: BMW Z3, Mercedes CLK430, Subaru BRZ
Idling characteristics with bad MAF sensor?
Does anyone know how an otherwise good running BRZ idles when the MAF sensor is bad or just disconnected? I think a piece of debris may have gotten sucked into my intake (embarrassing story) and ruined my MAF sensor. At idle my engine oscillates between 600 and 2200 rpm (about a 1 second frequency). It's not running good at all.
Thanks, Mike
mheffel is offline   Reply With Quote
Old 10-23-2014, 12:36 AM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
From experience the car should idle fine with the MAF disconnected, maybe a little rougher but it wouldn't be fluctuating like that. Typically people know a MAF is bad when the car runs better with it disconnected, signifying the MAF is giving a bad reading. I wouldn't drive without the MAF but you can start it up disconnected to get an idea. Was it large debris that would have impacted the sensor or just made it dirty?
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 10-25-2014, 07:08 PM   #3
mheffel
I disconnected the MAF, and the idle was still bad, so I figured the MAF was OK, per your advice. So, I moved up the air intake to the throttle body. I removed the flexible intake tube at the throttle body and after opening the throttle by hand found a 1/2" sliver of loose plastic. I removed it, and now the car runs perfectly again. I suppose the debris was somehow interfering with the throttle or throttle position sensor.
Old 10-26-2014, 07:32 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
That is scary. What was the plastic from? Could more of it have gone through your motor?
1974 TA22 Celica
2013 86 GT
Old 10-26-2014, 09:43 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Time to fess up. What did you do?
phrosty (10-27-2014)
Old 10-26-2014, 09:56 PM   #6
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
eeek, this sounds scary..
hope nothing made its way inside..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
6 speed m/t idling low Gt86_nick Engine, Exhaust, Transmission 1 01-28-2014 07:54 PM
*Coilovers & Sway Bars - How they alter handling characteristics. LET'S DISCUSS.* fc3s_johnny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-29-2013 06:13 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
