#15 |
| The Following User Says Thank You to Tcoat For This Useful Post: | p1l0t (10-16-2016) |
#16 |
Drives: 17 Alfa Romeo 4C
A warning that you haven't read your manual yet.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
| The Following 7 Users Say Thank You to Braces For This Useful Post: | finch1750 (10-16-2016), Hot-Lava_Dave (10-16-2016), humfrz (10-16-2016), p1l0t (10-16-2016), shellslinger (10-15-2016), Tectoniic (10-16-2016), Ultramaroon (10-16-2016) |
#17 |
....... because you haven't read your manual.another ....... because you should be able to figure it out, even if you didn't read your manual.Now, go put about 35 psi of air in all of your car's tires. ....... that one is just because I felt like it.![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | finch1750 (10-16-2016) |
#18 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (10-16-2016) |
#19 |
Also this, what's it for and how do I use it?
#20 |
No I just figured if he won't believe that the sound clip he made is a perfectly normal sounding boxer engine ( after asking if it was normal at that) then he would not believe that there is a such thing as a book that tells you all those hidden secrets. Even I sometimes know when to just give up.
Not sure if it is a cultural thing now or just a result of ease of information on the internet but damn it seems people go out of their way to try and find something wrong with their cars sometimes.
#21 | |
Remember, back-in-the-day, we just looked and listened to "the vital signs". * car ran out of gas - walk to the next farm and borrow a gallon of gas * car was billowing steam from under the hood - fill it with ditch water and wrap a rag around the busted radiator hose. * car vapor locked - place a wet rag on fuel line & re-prime * tire went flop-flop-flop - put on the spare * car flooded - hold open the choke with a pen, push accelerator to the floor and hold it while cranking the engine till it started * car wouldn't stop - downshift and apply emergency brake * car died at idle - take a screwdriver or a dime and turn idle screw clockwise a time or two. * car won't fire during damp weather - take off your T-shirt and dry out the distributor contacts * car is mis-firing - pull plug wires one at a time till you find the fouled plug, pull it and clean it up. * I'm sure you old timers can add to the list...... ![]() Now ....... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | p1l0t (10-16-2016) |
#22 | |
98% of the time the e brake cables were either seized solid or had snapped years ago. I am sure that people will counter with "well cars are more complex now". Yes, they are, but the quality of manufacture, vastly improved technology and materials more than make up for that. I find it entertaining that the same guys that will freak out and tell people to take their at in for a full cooling system flush because somebody put 4 ounces of the wrong coolant in it are also the ones that will change their whole suspension and discuss the merits of FI at length.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (10-16-2016) |
#23 |
#24 |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
#25 |
That would be a warning light that I would most certainly have to disable.
#26 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#27 | |
Result: |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#28 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
| Idling characteristics with bad MAF sensor? | mheffel | Engine, Exhaust, Transmission | 5 | 10-26-2014 09:56 PM |
| 6 speed m/t idling low | Gt86_nick | Engine, Exhaust, Transmission | 1 | 01-28-2014 07:54 PM |
| Idling Issue | ericmpena | Issues | Warranty | Recalls / TSB | 1 | 11-01-2013 12:21 AM |
| High idling on new FR-S | ndsleep612 | Issues | Warranty | Recalls / TSB | 19 | 07-27-2013 10:06 AM |
| Idling/RPM question | Crackseed | Hawaii | 3 | 02-24-2013 11:54 PM |
