#15 |
Remove your hood when you install it to control temps.
#16 |
Drives: 2014 GT86
Better add fan blowing on it
![]() But yes, due mentioned by Mike points of bad thermal properties, not sure slight weight savings are worth probably extraorbitant price and probable cracking issues. They could have at least make it long tube 4-2-1 to make interesting contender with Ace / Nameless with more area under curve. |
#17 |
just checked out your build and I would recommend you look at the ACE header for your build if it wasn't already in your list of options
http://www.ft86club.com/forums/showthread.php?t=80609
#18 | |
Drives: Subaru BRZ / Toyota 86 Experts
#19 |
Drives: 13 frs red
Wont be easy to do a shade tree weld repair on these.
#20 |
#21 |
[insert cool phrase here]
Drives: BRZ Premium
Is it really TI or just Ti coated?
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#22 |
Drives: 2012 FR-S
We have one
It comes with a high price tag and zero warranty. TI is just too vulnerable to cracking and with the close quarters of the FT chassis it just isn't something we want to push mainstream. Also without bending the design isn't optimal to the types of gains we prefer on our cars. We do have long term plans for inconel, but we're just not there yet. Why do we have one you ask? Because why not
#23 |
Anti stance.
#24 | |
Drives: 13 BRZ
321 headers are considerably more expensive but because of the materials fatigue resistance at high temps you can get away with thinner wall tubing and therefore a lighter header. Where .065" is suitable for 304 you can get away with 0.049" wall with 321. And same goes for inconel. Inconel headers can be insanely thin and still resist cracking. Like 0.029" wall thickness! If you ever get the chance to pick up a set of indycar, F1, GTLM, etc. headers they feel like tin foil. It's crazy! Here is a more informative post on header materials: http://www.enginelabs.com/engine-tec...-race-headers/ |
#25 | ||
Resident Gear Head
trying to finish this engine, By the time I am done I could have bought a 2nd used 86 with the money invested... I need some partners, @AceHeader-MT 13:1 CR Bored sleeved Stroker 2.3ltrs Custom rod to stroke ratio Piper Race cams Ferrea complete valvetrain Goal exceed 275 WHP at 9500RPM
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
#26 | |
#27 | |
Drives: Subaru BRZ
Sent from my SAMSUNG-SM-G900A using Tapatalk
#28 |
Drives: H4WD
There are some examples with titanium application for exhaust systems in f1. Even now.
Not just Inconel. If you can find a special titanium alloy,there is no problem even with cracks. VT18m as a sample. Usually it is the back side of exhaust systems,but in case of f1 car,it is still hot enough..Titanium heat conductivity is low,this is why temperature drop is lower and gases speed is higher. |
| WINDOW WONT GO UP! | Moe23 | Issues | Warranty | Recalls / TSB | 26 | 02-07-2022 02:20 PM |
| Lugs wont fit | ChrisP | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-01-2016 01:23 PM |
| Does anyone manufacture a 3" resonated no-cat front pipe? | boomslang | Engine, Exhaust, Transmission | 2 | 09-04-2014 08:22 PM |
| 6MT wont shift? | StRacngtC06 | Issues | Warranty | Recalls / TSB | 14 | 01-07-2014 11:59 AM |
| Car Wont Start Up HELP !!*** | ScionFR-S | Issues | Warranty | Recalls / TSB | 20 | 11-28-2013 01:01 AM |
