Old 05-28-2013, 01:58 PM   #491
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by nonicname View Post
I really wish somebody had said this since the beginning.
This is how all REAL parts companies work...It's sad that it needs to be stated and restated so much.
I spent a good while chatting with the innovate peeps this weekend, they are in no hurry to sell bad product, they are shaking stuff down and verifying everything, just like it should be,
Last edited by SkullWorks; 05-28-2013 at 02:00 PM. Reason: Not enough coffe yet today
Old 05-28-2013, 01:59 PM   #492
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I spent a good while chatting with the Innovate peeps this weekend, they are in no hurry to sell bad product, they are shaking stuff down and verifying everything, just like it should be,
Fixed that for you.
Old 05-28-2013, 02:00 PM   #493
SkullWorks
Fixed that for you.
Thank you, needs more coffee
Old 05-28-2013, 02:15 PM   #494
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by xxscaxx View Post
So this is from straight e85 consumption...would a "wash" of regular pump gas take care of this problem, or do you feel its inevitable when running e85?
Kind of bummed since I am waiting for an e85 tune right now.
Yea, lets talk more about this! If this is the case, im switching back to pump gas in the next couple of days. This is kind of a bummer....
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-28-2013, 02:30 PM   #495
Frostyman
Drives: 2013 Raven FRS
Yikes!!! Looks like I need to swap back to pump gas now too. Let's talk about cleanup, if this happens to anyone. How do we get the gunk gone? My panic level just spiked.
Frostyman is offline   Reply With Quote
Old 05-28-2013, 02:31 PM   #496
robispec
Drives: Black frs project
I was lucky as I have many friends in the tc community they hit the problem FIRST TRY.. seems their intank filter does the same on their e-85 boosted cars too... I'm ASSUMING regular gasoline with ocasional e-85 uses will prevent this ...No Dangit I wont go there... ALL alcohols are SOLVENTS too...and they work particularly well on adhesives....like the kind glueing the felt material to the filter pleats...so with Murphy in mine if it can fail it will...and at the worst possible time.
We
Cleaned the tank and all feed and return lines
Replaced the intank pump
Replaced the port injectors
Replaced Direct injection pump
Replaced/cleaned all DI hardlines
Replaced the direct injectors
We did this from the tank forward in sequence to try and isolate the restrictions.
Car did not run clean till EVERYTHING had been serviced/replaced/cleaned..
ALL E-85 users I would LOOK at your intank sump bowl. ANY DEBRIS means your return fillter is disintegrating...
robispec is offline   Reply With Quote
The Following 3 Users Say Thank You to robispec For This Useful Post:
Frostyman (05-28-2013), Pete (05-28-2013), TemeCal (05-28-2013)
Old 05-28-2013, 02:31 PM   #497
Opposed
Yea, seriously. Should we open a new thread dedicated to this? This is the first time I have heard of E85 damaging the stock fuel system. But I guess it was bound to happen...
Old 05-28-2013, 02:35 PM   #498
sw20kosh
Drives: 2013 Black FR-S
This effect will be more pronounced / happen earlier on Robi's car since it is tracked like crazy and doesn't see pump.
Looks like it is inevitable for everyone esle though...just a matter of time. Time to find an E85 compatible fuel filter? Shouldn't be too hard right?
Old 05-28-2013, 02:35 PM   #499
xxscaxx
Drives: 2013 SWP BRZ
We
There goes me running E85 for now until some kind of fix is in place.
This really sucks.
xxscaxx is offline   Reply With Quote
Old 05-28-2013, 02:39 PM   #500
tom@kartboy
tom@kartboy's Avatar
Drives: American Made Shift!
What about a flex fuel filter? isnt there a tahoe or a ford truck that we could adapt the filter?
tom@kartboy is offline   Reply With Quote
Old 05-28-2013, 02:39 PM   #501
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
We
@robispec can you please make a new thread for E-85 problems and possible solutions to solve the issue before it starts. Not running E-85 is the worse possible fix for this, maybe we can look at the fuel system and create a solution.
Btw heads up to @moto-mike
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-28-2013, 02:40 PM   #502
Sportsguy83
Drives: Limited BRZ
New thread created:
http://www.ft86club.com/forums/showthread.php?t=37706
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
Calum (05-28-2013), Frostyman (05-28-2013), Opposed (05-28-2013), Sonolin (05-28-2013)
Old 05-28-2013, 02:57 PM   #503
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
yes but does the stock intank Scion fuel filter disintegrating and contaminating/restricting the ENTIRE fuel system???
Robi
As mentioned before, this is not a "FlexFuel" car so people running E85 are doing so at their own risk.
rice_classic (05-28-2013)
Old 05-28-2013, 07:10 PM   #504
Carticular
Drives: Mazda3
Loving this!
Carticular is offline   Reply With Quote
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
