Old 05-17-2013, 06:47 PM   #15
troek
troek's Avatar
Drives: 2012 Toyota 86
yeah i agree with the others about toe., however i dont think 1.5 degree camber will throw your toe off very much, but this is my first McPherson strut car. at the very least look up some DIY ways to check your toe. having toe off is THE fastest way to wear your tires down. that app will not help you with toe. it can only measure vertical angle differences.
troek is offline   Reply With Quote
Old 05-19-2013, 09:16 PM   #16
Ozzman
Drives: old
It can throw your toe off as much as 2 degrees, which will eat the hell out of tires. Go take the car to get a proper alignment done.
Ozzman is offline   Reply With Quote
Old 05-19-2013, 09:46 PM   #17
troek
troek's Avatar
wow yeah, 2 degrees is alot. is it common on this car to have the toe thrown off this much, or is that a worst case scenario? i went all the way to -3 degrees camber on my r32 and kept toe alignment, but that is double wishbone.
Old 05-19-2013, 10:30 PM   #18
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Originally Posted by f0rge View Post
SPC LCAs are only $300, i went this route
Also went this route. Put in the SPC toe arms as well since I was in there.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 05-20-2013, 09:39 AM   #19
wparsons
wparsons's Avatar
Originally Posted by eljefe View Post
Are you guys trying to correct your camber, or get it to be more negative? im confused.
When i dropped my car the rear went negative so i want to bring it back to zero, obviously i cant use these cam bolts, so is my only option to buy 500 dollar LCA's?
Crash/camber bolts will let you run less camber up front as well... and no one makes a LCA with camber adjustment for the fronts.
Your only options for camber adjustment in the front is the camber/crash bolts, slotted upper hole on the struts or adjustable upper mounts.
For the rears you can use the camber bushing, modified camber/crash bolt or adjustable arms (either upper or lower).
flickr
Old 05-20-2013, 10:06 AM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
http://www.ft86club.com/forums/showthread.php?t=31424
http://www.ft86club.com/forums/showthread.php?t=30963
Old 05-20-2013, 04:35 PM   #21
donutfilling
donutfilling's Avatar
Drives: frs
Not even the factory alignment has 0 camber.. I don't think you would want 0 camber in the rear.
donutfilling is offline   Reply With Quote
Old 05-21-2013, 11:55 AM   #22
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
After installing the SPC arms my alignment was a disaster, way worse than after having just done the springs. Toe was especially messed up but they were able to get it into spec without having to install the toe bushings or get adjustable toe arms. The factory arms are adjustable.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 05-21-2013, 04:11 PM   #23
wparsons
wparsons's Avatar
I wouldn't touch those for camber adjustment, way too easy to mess up caster and other adjustments when trying to adjust camber. With a strut I'd much rather have slotted struts or adjustable upper mounts.
I have the same opinion for adjustable LCA's for the rear, you *need* adjustable trailing links too to keep everything lined up right.
flickr
Old 05-21-2013, 04:27 PM   #24
Calum
That Guy
The factory toe arms are adjustable, but the trailing link isn't. But if you're adjusting the LCA and toe arm, you really should be adjusting the trailing link. And the cycle continues.
I wouldn't either. I only posted the links to show that they exist. I have whiteline camber bushings for the rear but I'm not really sure about installing them and trusting a shop to ensure that both bushings per side are clocked to the same position, to ensure they don't add caster while they're adjusting camber. I'd really like to see a single adjustable UCA that isn't stupidly expensive.
Actually, that's a lie, what I really want to do is base line the alignment and find that the rear is exactly where I want it.
The Following User Says Thank You to Calum For This Useful Post:
wparsons (05-21-2013)
Crash Bolt Part Number? Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 10-18-2013 12:02 AM
Crash bolt installation question slowbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-01-2013 12:37 AM
Trying to find service manual info on crash bolt 2point0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-17-2012 02:07 PM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 01:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
