Old 08-17-2012, 10:55 AM   #1
ayau
Drives: Some rust bucket
Crash bolt question
as some of you know, oem crash bolts are allowed in scca stock class.
you can purchase them here.
http://www.subarupartswebsite.com/OE...901000394.html
after i install the stock bolt with the crash bolts, do i need to bring my car to an alignment shop to get it re-aligned? what's the difficulty level of installing the crash bolts? can i make camber adjustments myself, and what tools would i need?
Old 08-17-2012, 10:58 AM   #2
schtebie
Drives: CBS BRZ Limited
The crash bolt installation is straight forward...it simply replaces the top strut bolt and it's held on by friction. You'd use the same tools you use for installation of your front struts.
schtebie is offline   Reply With Quote
Old 08-17-2012, 11:08 AM   #3
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I installed my yesterday and it doesn't seem to change the front toe so I would guess no, no need for an immediate alignment. However every before post I've seen of these cars the factory alignment was in question so I'd consider it anyway.
Basically you just take off a front wheel, loosen up the two 19mm nuts/bolts that hold the hub to the strut and remove the top one. Replace that with the new bolt and re-use the old nut. While holding the top of the brake rotor inwards to give you the most negative camber possible, tighten both nuts/bolts. Torque spec I believe was 180ft/lbs but confirm that elsewhere, I just do it a ton so it will not slip. Reinstall wheel, repeat on other side and then you are done. Took me about 15 minutes to do both sides using the center jacking point under the front of the car.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-17-2012, 11:11 AM   #4
Racecomp Engineering
And you will need to realign the car after installing them.
Old 08-17-2012, 11:12 AM   #5
ABQautoxer
ABQautoxer's Avatar
Did you measure how much the toe changed after you installed them?
TomR
Old 08-17-2012, 11:50 AM   #6
ayau
thanks everyone for the constructive feedback.
it's been a while since i had an alignment done. about how much do they cost?
Old 08-17-2012, 11:57 AM   #7
dsgerbc
Drives: BRZ(sold), STI
^Depends on who's doing it. When I was back in Mpls, the go-to guys for local autox-ers was 'Jeff the alignment guy'.
He's not the cheapest, but he was highly regarded. That was few years ago, but I imagine he's still doing it.
I think it was ~$70-$80 for a 4-wheel alignment last time I used him. Should be less for just two.
dsgerbc is offline   Reply With Quote
Old 08-17-2012, 12:05 PM   #8
ayau
thanks, but i might as well have the rears aligned too if they're questionable from the factory.
for those who installed the crash bolts, did you adjust for max negative camber at the front and stock alignment for the rear? what about toe adjustments?
Old 08-17-2012, 01:22 PM   #9
I can't remember to be honest and we wanted to address the crappy factory alignment anyway. It was enough that I would highly recommend getting a full alignment afterwards, but I'm pretty anal about that stuff in general.
- Andrew
Camber Bolt Help Please! ft86Fan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 114 02-27-2019 11:13 AM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-29-2012 11:30 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
first 86 crash just86 Scion FR-S / Toyota 86 GT86 General Forum 31 03-12-2012 01:23 PM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 06:04 PM
