Drives: black frs
Just installed crash bolt.
I just put the 901000394 camber bolts in the front. I figured some people would line to see the difference so heres a pic of before and after. Can anybody estimate the camber I have right now?
| The Following User Says Thank You to normanb21 For This Useful Post: | Anthonytpt (05-17-2013) |
#2 |
Drives: '13 DGM BRZ Limited
| The Following User Says Thank You to cnk For This Useful Post: | Anthonytpt (05-17-2013) |
#4 |
Drives: WRB BRZ Limited
I can tell you after installing those bolts and a 1" drop I had -1.5°
#5 |
Drives: 2012 Toyota 86
theres an app called clinometer if you have an iphone. its been accurate within .1 degree on me and my buddies cars after alignment.
#6 |
Drives: SS BRZ LMTD 6MT, 92 Civic hatch RHD
Are you guys trying to correct your camber, or get it to be more negative? im confused.
When i dropped my car the rear went negative so i want to bring it back to zero, obviously i cant use these cam bolts, so is my only option to buy 500 dollar LCA's? |
#7 |
Drives: black frs
I was tryin to get more negative. I'm still on stock ride height
#8 | |
1. Raise the car up 2. Get LCA's 3. Get UCA's 4. Get Whiteline UCA bushings 5. Some have used a modified camber bolt in the LCA to subframe connection to get some camber adjustment. |
| The Following User Says Thank You to cnk For This Useful Post: | eljefe (05-17-2013) |
#9 |
Drives: black frs
#10 |
head of infinite swagger
Drives: 2013 FR-S 6MT
SPC LCAs are only $300, i went this route
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
| The Following User Says Thank You to f0rge For This Useful Post: | deucethemoose (05-19-2013) |
#11 |
Drives: 2013 Asphalt FR-S
I hope you plan on an alignment .. change to camber changes toe as well and you really need to set it up properly if you want it to handle correctly. camber is almost never the same side to side stock, so maxing out the lobe on the crash bolts will not result in the same camber on each side and as a result toe will not only change, but likely go wonky (more toe in or out one side than the other).
~Namaste~ |
#12 | |
Drives: black frs
#13 |
Adjust or measure?
A few ways to measure, search google and youtube. To adjust, look at the tie rod ends for a lock nut, the look on the steering arm for an octagonal section designed for a wrench, loosen the lock nut, turn the arm to adjust, re tighten lock nut. Unless your going to spend a lot of time making 4 level (with each other) slip plate platforms (cheap way is using water level, floor tiles, and table salt) and learning to do a full string alignment, your better off going to a reputable shop. It's very easy to screw your alignment up. Better off to get a good alignment to start with, then see if you can perfect your measuring system to get the same numbers they got on the rack. Then, make a few small changes and see if you can get it back to the original settings etc etc.
~Namaste~ |
#14 |
you probably have around 1 degree. That's all I was able to get with crash bolts. Now that I have RCE yellows and crash bolts, I have 1.4
| Crash Bolt Part Number? | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 10-18-2013 12:02 AM |
| Crash bolt installation question | slowbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-01-2013 12:37 AM |
| Trying to find service manual info on crash bolt | 2point0 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 10-17-2012 02:07 PM |
| Crash bolt question | ayau | Tracking / Autocross / HPDE / Drifting | 8 | 08-17-2012 01:22 PM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
