Old 10-03-2012, 05:09 PM   #1
Dezoris
Dezoris's Avatar
Crash Bolt Part Number?
Can someone provide the part numbers for the crash bolts on the FR-S and BRZ?
Old 10-03-2012, 07:23 PM   #2
gmookher
do search
gmookher is offline   Reply With Quote
Old 10-04-2012, 01:39 AM   #3
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
It is on the forums here, but the part number to the crash bolts, or camber bolts is:
901000394
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 10-07-2012, 01:51 AM   #4
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Took some pics while installing mine today, hope this helps.
Of the 2 bolts that attach the strut to the hub, replaced the upper one. Also loosened the bottom nut to allow smooth articulation before tightening both back up.
Here is the difference between the 14mm camber bolt vs. the 16mm stock bolt. The 14mm bolt allows slight adjustment, I guess ~2mm against the 16mm hole.
I don't have a camber gauge, but did verify gain of negative camber.
I set a vertical straight edge up against the tire at the ground & against the fender on top (at centerline of the wheel by positioning it visibly centered through the center cap).
Using a horizontal ruler/tape measure, measured the distance from edge of the vertical straight edge to the top edge of the wheel.
Stock = distance was 0.8"
After 14mm camber bolt = distance was 1.1" after settling/driving.
No idea what degree gain that is, but roughly playing with numbers on an online triangle calculator seems to indicate about a 1 degree gain in negative camber.
Only went for a short drive today, but I feel the tires squealing easier than before? Maybe I am hearing the rear instead of the fronts now? From what I felt on today's short drive, I think I prefer the stock setup for the street, lol.
Will have to wait for Saturday autocross practice day to see what it handles like when pushed harder.
brz7400 is offline   Reply With Quote
Old 10-07-2012, 02:09 AM   #5
ayau
Drives: Some rust bucket
awesome pics and directions. do you think it's better off to get an alignment after the install? if you just do the bolt swap, will that mess up the toe/caster?
The Following 2 Users Say Thank You to ayau For This Useful Post:
brz7400 (10-07-2012), MrFisty (04-25-2016)
Old 10-07-2012, 01:44 PM   #6
brz7400
brz7400's Avatar
Drives: Subaru BRZ
That's a good point. Since caster remains the same, I guess negative camber with tie rod on the backside of the hub would change toe to slightly in? Is that why I felt the tire squeals easier than before? Did I end up getting more understeer by doing camber bolts without getting alignment?
That's not gonna be good at the autocross!
Old 10-08-2012, 03:28 PM   #7
Dezoris
Dezoris's Avatar
Thanks for posting this up!!
However I realize the part is interchangeable but does Scion have a part number for the same bolts? Or is the part number the same?
Old 10-08-2012, 03:30 PM   #8
Dezoris
Dezoris's Avatar
Found It:
Scion Part Number: SU003-02818
Old 10-08-2012, 04:03 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Dezoris View Post
Found It:
Check pricing BTW. IIRC someone said Scion sold them for more but I can't recall for sure. I think I paid around 9.50 or so total for two bolts.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-08-2012, 08:46 PM   #10
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
With tax Scion charged me $17.03 for the 2 bolts
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 10-08-2012, 08:51 PM   #11
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
The squealing might be from your toe falling out of spec during the install. Mine did.
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
brz7400 (10-09-2012)
Old 10-08-2012, 08:53 PM   #12
ft86Fan
ft86Fan's Avatar
Were you able to get the additional camber gain by just loosening the 2 bolts that attach the strut to the hub (of course after replacing the top bolt)? Did you also have to loosen the strut top?
Old 10-09-2012, 01:36 AM   #13
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Only need to loosen the 2 bolts that attach lower part of the strut to hub. That allows the hub to lean slightly inward, then tighten back up.
Minimal work really, (5 nuts to get wheel off + 1 nut off to replace bolt + loosen 1 nut to allow hub rotate inward, then tighten back up) X 2.
The Following User Says Thank You to brz7400 For This Useful Post:
ft86Fan (10-09-2012)
Old 10-09-2012, 01:45 AM   #14
brz7400
brz7400's Avatar
Drives: Subaru BRZ
Thanks for the confirmation, that's what I am figuring, I have introduced slight toe in. Guess I could easily shorten both tie rods a turn each, but that may require few adjustments if a turn is not enough/too much.
I forgot to grab the square tube toe gauge thing that I have stored at my old man's house, so may just wait until weekend to check/play with the toe setting...
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 06:25 PM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 02:22 PM
Part number or name for this clip TrickyFrenchman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 07-16-2012 11:50 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 09:30 PM
