#15 |
Drives: Whiteout Scion FR-S
Lug Nuts, do they matter?
Answer: Apparently not! I see people driving cars around with one or two lug nuts missing all the time. ![]() Seriously though, great thread as I too wanted to know more about this topic. David, could you elaborate on the titanium pros and cons. I know they are VERY expensive, strong and lightweight. What are other issues with them?
My cars always dress formally. They all wear black tires.
| The Following User Says Thank You to Black Tire For This Useful Post: | jonnyozero3 (04-13-2013) |
#16 |
I used these in the past but for the life of me couldn't remember the brand until you mentioned them. They are also 7075-T6 aluminum and not very expensive for the set, come in lots of colors if that's your thing.
#17 |
Drives: '13 GBS Subaru BRZ
Keep in mind lightweight aluiminum or even titanium lugnuts need more attention. Steel lug nuts you can usual put them on and forget about them. Aluiminum should be retorqued on a regular basis. They can loosen over time much more the steel.
| The Following 2 Users Say Thank You to neutron256 For This Useful Post: | Anthonytpt (04-09-2013), stevo_12v (05-06-2013) |
#18 | |
Ti is brittle. You don't want it to see any impacts. It also hates vibration and heat cycles (which is why Ti exhausts baffle me... even though I loved mine...) Other than that, Ti is just prohibitively expensive. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Black Tire (04-09-2013) |
#19 |
Other than pure looks/bling, why can't you use your factory lugs on aftermarket wheels?
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#20 | |
Drives: Some rust bucket
Aftermarket wheels have a conical wheel seat, which means you need a conical lug nut to seat them properly. On the other hand, Hondas have a rounded wheel lug nut, which means they won't seat properly when mated with an aftermarket wheel with a conical seat. |
#21 |
I'm about 95% sure Subaru has a conical wheel seat and lug nut.
#22 |
Drives: Attitude
#23 |
Yup, the "seat length" is shorter than your standard aftermarket lug nut/wheel. I'd still recommend aftermarket conical lug nuts for aftermarket wheels.
#24 | |
Maybe I should actually look at them.... ![]() *edit* Looks like I put my foot in my mouth. I stand corrected. Embarrassing, considering I used to have an STi too... |
| The Following User Says Thank You to CSG Mike For This Useful Post: | jonnyozero3 (04-13-2013) |
#25 |
So then I should pick up a set of aftermarket lugs if I go with aftermarket wheels.
#26 |
Frosty Carrot
Drives: The Atomic Carrot
I used my stock lug nuts with the new wheels. They were both conical.
When you install new wheels, make sure to tighten them on sufficiently. Any manufacturing process will have some tolerance associated with it. Tightening the nuts on well will "coin" the surface so that it mates up properly for the remaining service life. I noticed a little metal bunched up along the inside diameter of the stud holes (which is OK).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
#27 |
Drives: Supercharged Saturn ION
Get a set of Muteki lug nuts and be done with it. Doesn't matter which model, they're all solid.
I prefer black Muteki SR35 lug nuts or just the basic closed end ones if you're on a budget. |
#28 |
Drives: 4 wheels & some metal bits
I was looking for the "why" behind such decisions. Not just, "I like x". That doesn't help me learn.
| **BEST Lug Nuts with Lock*** | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 05-25-2014 04:22 PM |
| Will these lug nuts fit? and are they good? | MarkMash | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 01-14-2013 12:01 PM |
| Lug Nuts? | Reflex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 10-21-2012 07:38 PM |
| Does CAI brand matter or just the filter? | ngabdala | Engine, Exhaust, Transmission | 16 | 08-26-2012 01:36 AM |
| ARE YOU GONNA BUY IT NO MATTER WHAT | serchmarc | Scion FR-S / Toyota 86 GT86 General Forum | 97 | 03-19-2011 05:27 PM |
