Old 10-21-2012, 07:32 AM   #1
Reflex
Drives: Whiteout FR-S
Lug Nuts?
Are all lug nuts the same size? I'm asking because on discount tire, they advertise a lug kit with the purchase of a set of rims because they claim that "original equipment lug hardware will not work on aftermarket wheels."
I don't want to spend $45 on this wheel installation kit if stock lugs or bolts already work..
Reflex is offline   Reply With Quote
Old 10-21-2012, 07:46 AM   #2
Zadkiel
Drives: CBS BRZ Limited 6MT
I bought some wheels from discount tire and they packaged a lug nut kit in mine. I think they're right though. The stock lug nuts were a bit too large to fit in the holes for the aftermarket wheels. They send a Gorilla Lug Nut kit.
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 10-21-2012, 07:59 AM   #3
Reflex
So does that mean only certain lug nuts fit with certain wheels? Or do OEM lug nuts have their own special size and all aftermarket ones are universal?
Old 10-21-2012, 08:43 AM   #4
avp1
Drives: Traded BRZ for Supra
Some aftermarket wheels will work with stock lug nuts. But in most cases they require specially made ones. I am surprised that wheels you chose do not come with its own set of lug nuts. Usually they sold together as a set.
avp1 is offline   Reply With Quote
Old 10-21-2012, 05:06 PM   #5
Nardi330
Nardi330's Avatar
Drives: 86
I don't know what wheels you are buying but most aftermarket wheels use a tapered design which is different to OEM. You will need the correct nuts for fitting properly.
A lot wheels manufacturers sell lug nuts seperately.
Nardi330 is offline   Reply With Quote
Old 10-21-2012, 07:32 PM   #6
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Looks similar but I wouldn't risk it
Originally Posted by F1point4 View Post
Hrmm, another photo opportunity? Let's do it.
Although the cone is shallower, looks like a fit to me. These are Muteki SR35 lugs.
20121016-86_Lugnuts_M12x125-03 by VictorN07, on Flickr
20121016-86_Lugnuts_M12x125-01 by VictorN07, on Flickr
20121016-86_Lugnuts_M12x125-02 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
JoeBoxer (10-21-2012)
Old 10-21-2012, 07:38 PM   #7
cnk
Drives: '13 DGM BRZ Limited
Stock lug nuts are known as acorn nuts and aftermarket lugs do not have the same taper as acorn nuts. I usually only use the OEM lugs on OEM rims and use aftermarket lugs on aftermarket wheels just to avoid any issues with the lugs not being able to properly secure the wheels to the hub.
cnk is offline   Reply With Quote
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 08:39 PM
Stock Lug Nuts?? ESC POD Northwest 8 10-15-2012 12:43 AM
WTB: 73-56.1 hubrings and 12x1.25 lug nuts JoeBoxer Wheels and Tires 3 09-04-2012 05:26 PM
Need Lug Nuts? Wheels? Hit us up! -FullyBolted.com Josh@FullyBolted.com Wheels and Tires 1 06-25-2012 02:04 PM
Calling all wheel nuts. Staticfrost AUSTRALIA 90 06-13-2012 09:33 AM
