Old 04-09-2013, 10:15 AM   #15
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Lug Nuts, do they matter?
Answer: Apparently not! I see people driving cars around with one or two lug nuts missing all the time.
Seriously though, great thread as I too wanted to know more about this topic.
Originally Posted by CSG David View Post
Lug nuts come in a variety of materials. My personal favorites are painted chromoly steel and anodized aluminum 7075-t6. Titanium has its pros/cons.
David, could you elaborate on the titanium pros and cons. I know they are VERY expensive, strong and lightweight. What are other issues with them?
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
The Following User Says Thank You to Black Tire For This Useful Post:
jonnyozero3 (04-13-2013)
Old 04-09-2013, 10:42 AM   #16
xwd
Originally Posted by TRev View Post
I have used VMS Racing lugs on a few cars now and no problems. Just need to make sure to torque them properly and not use an impact to break them loose. The ones I have for the BRZ are 19 grams.
I used these in the past but for the life of me couldn't remember the brand until you mentioned them. They are also 7075-T6 aluminum and not very expensive for the set, come in lots of colors if that's your thing.
Old 04-09-2013, 11:02 AM   #17
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Keep in mind lightweight aluiminum or even titanium lugnuts need more attention. Steel lug nuts you can usual put them on and forget about them. Aluiminum should be retorqued on a regular basis. They can loosen over time much more the steel.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
Anthonytpt (04-09-2013), stevo_12v (05-06-2013)
Old 04-09-2013, 11:35 AM   #18
CSG Mike
CSG Mike's Avatar
I'm not an engineer, but David is a mechanical engineer by trade. I do, however, have enough automotive experience to tell you this.
Ti is brittle. You don't want it to see any impacts. It also hates vibration and heat cycles (which is why Ti exhausts baffle me... even though I loved mine...)
Other than that, Ti is just prohibitively expensive.
Black Tire (04-09-2013)
Old 04-09-2013, 12:53 PM   #19
zoomzoomers
zoomzoomers's Avatar
Other than pure looks/bling, why can't you use your factory lugs on aftermarket wheels?
Old 04-09-2013, 01:12 PM   #20
ayau
Drives: Some rust bucket
On the BRZ, I believe you can. It's all about the shape of the end of the lug nut (where the lug nut mates with the rim).
Aftermarket wheels have a conical wheel seat, which means you need a conical lug nut to seat them properly. On the other hand, Hondas have a rounded wheel lug nut, which means they won't seat properly when mated with an aftermarket wheel with a conical seat.
Old 04-09-2013, 01:14 PM   #21
ayau
Factory lugs are ball seats, while aftermarket are conical. If you mismatch lugs/wheels, then you won't be properly holding the wheels onto the hubs.
CSG lugnuts are conical, and are for use on aftermarket wheels only.
I'm about 95% sure Subaru has a conical wheel seat and lug nut.
Old 04-09-2013, 01:15 PM   #22
OrbitalEllipses
Drives: Attitude
Factory lugs are ball seats, while aftermarket are conical.[/img]
Subaru factory lugs are CONICAL seat. 60 degree taper like aftermarket. Much smaller seat than an aftermarket lug though.
Old 04-09-2013, 01:17 PM   #23
ayau
Yup, the "seat length" is shorter than your standard aftermarket lug nut/wheel. I'd still recommend aftermarket conical lug nuts for aftermarket wheels.
Old 04-09-2013, 01:28 PM   #24
CSG Mike
CSG Mike's Avatar
Oh wait what?
Maybe I should actually look at them....
*edit*
Looks like I put my foot in my mouth. I stand corrected.
Embarrassing, considering I used to have an STi too...
Old 04-09-2013, 02:15 PM   #25
zoomzoomers
So then I should pick up a set of aftermarket lugs if I go with aftermarket wheels.
Old 04-09-2013, 02:56 PM   #26
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
I used my stock lug nuts with the new wheels. They were both conical.
When you install new wheels, make sure to tighten them on sufficiently. Any manufacturing process will have some tolerance associated with it. Tightening the nuts on well will "coin" the surface so that it mates up properly for the remaining service life. I noticed a little metal bunched up along the inside diameter of the stud holes (which is OK).
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 04-09-2013, 05:38 PM   #27
NJA
Drives: Supercharged Saturn ION
Get a set of Muteki lug nuts and be done with it. Doesn't matter which model, they're all solid.
I prefer black Muteki SR35 lug nuts or just the basic closed end ones if you're on a budget.
NJA is offline   Reply With Quote
Old 04-13-2013, 12:45 AM   #28
jonnyozero3
Drives: 4 wheels & some metal bits
I was looking for the "why" behind such decisions. Not just, "I like x". That doesn't help me learn.
jonnyozero3 is offline   Reply With Quote
**BEST Lug Nuts with Lock*** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 05-25-2014 04:22 PM
Will these lug nuts fit? and are they good? MarkMash Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-14-2013 12:01 PM
Lug Nuts? Reflex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-21-2012 07:38 PM
Does CAI brand matter or just the filter? ngabdala Engine, Exhaust, Transmission 16 08-26-2012 01:36 AM
ARE YOU GONNA BUY IT NO MATTER WHAT serchmarc Scion FR-S / Toyota 86 GT86 General Forum 97 03-19-2011 05:27 PM
