Old 08-25-2012, 09:25 PM   #1
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Question Does CAI brand matter or just the filter?
I have a buddy that has modded cars and currently works for New York Transit as a mechanic for buses.
He suggests I buy the cheapest CAI I find on Ebay and to switch out the filter with a quality one. He says it's not the CAI brand that matters, it's the filter. I was going to pre-order the AfE Takeda for $367 but now I'm hesitant to.
Anyone know if this is true?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-25-2012, 09:39 PM   #2
mike2100
mike2100's Avatar
Drives: 23 BRZ
Unless you've swapped in a bus engine I'd say unlikely.
mike2100 is offline   Reply With Quote
Old 08-25-2012, 09:41 PM   #3
ngabdala
Lol. My friend has modded his cars. He's a good mechanic car or bus
And, alot of people make their own intakes. Maybe he's right. As long as there is a tight-seal that is.
Old 08-25-2012, 10:16 PM   #4
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
There is a difference between intakes. Tube deigns, where it's pulling air from, fit and finish, and etc. Not all are alike. Sure there is a basic concept but there are differences.
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-25-2012, 10:22 PM   #5
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
If the run is the same it will likely be close. Some of the higher end intake mfgs will put a thermal paint on their tubes vs. the bare ones you see and they claim that this helps reduce heat transfer.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-25-2012, 10:39 PM   #6
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Ok this is the reality! So far cold air intakes dynos show about a 7hp gain and that's pretty weak compared to the 5hp gains that a drop in filter makes (per dyno testing). People can think they know what they are talking about (most the time its people who have never had a car tunes) but you gain more hp by altering the part of the air box before the filter, the use of a velocity stack with some type of ram air entry to the air box will help most with a drop in filter. I also like to use silicon hoses from the throttle body to the air box to make a smoother flow with less heat soak to keep the engine temperature down.
20valvewynn83 is offline   Reply With Quote
Old 08-25-2012, 11:20 PM   #7
ngabdala
Based on the 7hp "pretty weak" dyno results on the CAIs would you recommend I hold off on buying one until there are better performing ones?
I'm interested in the aFe Takeda CAI which produced +9hp +10tq
http://afepower.com/shop/details_new...ily&brandID=78
Old 08-25-2012, 11:35 PM   #8
20valvewynn83
You will not get 9hp from that system, it will give 7hp gain and 9hp peak meaningits not a consistent 9hp. Don't get me wrong its a good intake but with some other mods with a tune you will be good. If you find a post that i made about a rubbwe tube you will see what I'm going for. Best thing to do is drop a filter in and wait
Old 08-25-2012, 11:37 PM   #9
FT-86 SpeedFactory
A tune with parts will make this car shine, just as any other.
A part alone will net small gains. A part with a tune to take advantage of the increased air flow will net even larger gains.
A tune should be on anyone's list as they add parts to their car. You decide when you take that plunge.
Old 08-25-2012, 11:39 PM   #10
ngabdala
I did a search for a rubbwe tube and this is the only post I found those words/ lmao
I'm guessing you meant rubber tube.
Old 08-25-2012, 11:46 PM   #11
ngabdala
Are you getting the full kit from Zeta? Which filter? Purple or Silver?
I want it now
Old 08-26-2012, 12:05 AM   #12
20valvewynn83
Haha yeah that's what I ment sorry I was using my phone
Old 08-26-2012, 12:09 AM   #13
20valvewynn83
I want it now
Depending on the price of the filers I will see. But if I do I prefer dry filters but I haven't made q choice yet.
Old 08-26-2012, 12:10 AM   #14
ngabdala
I hear oiled has more air-flow and they can also be cleaned and re-oiled. The trick is not too much oil or MAF goes nutty
Oil Filter Hayashi Hawaii 2 02-20-2013 12:07 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
ARE YOU GONNA BUY IT NO MATTER WHAT serchmarc Scion FR-S / Toyota 86 GT86 General Forum 97 03-19-2011 05:27 PM
