Old 03-04-2013, 09:22 PM   #29
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by SubaruBRZLimited View Post
Subaru should have the ability to customize set the air system so the AC doesn't come on unless the button is pushed. A true automatic system should work both ways, fully manual or auto.
This might be a BRZ problem because my GTS86 works fine apart from selecting the direction the airflow will take and that might be for the best on auto?
sierra is offline   Reply With Quote
Old 03-04-2013, 09:25 PM   #30
Burrcold
Drives: Subaru BRZ Limited
My BRZ limited does not do this either, so you guys are obviously doing something wrong or there is something wrong with the car.
Old 03-04-2013, 09:29 PM   #31
Brzetto
Drives: 4 wheels
I can select the direction and what not just fine, my only gripe is the automated A/C activation. I will eventually figure out how to defeat it. I would play with the air system a little more if it would stop snowing and raining on a weekly basis since my car is covered.
Brzetto is offline   Reply With Quote
Old 03-04-2013, 09:44 PM   #32
sierra
Perhaps it's a setting option the dealer can change through the ECU?
Old 03-04-2013, 09:48 PM   #33
Brzetto
Drives: 4 wheels
That's possible or there is some secret setting an owner can discover.
Old 03-04-2013, 09:52 PM   #34
sierra
Like holding a switch down for 3 seconds?
Old 03-04-2013, 10:02 PM   #35
Brzetto
Drives: 4 wheels
Yeah maybe. I won't guarantee anything though but it never hurts to explore that.
Old 03-04-2013, 10:10 PM   #36
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
I agree, I just don't drive it much in the winter months to find out. Just have noticed it the few times I have been able too. Spring is coming. Woot!
Dorb is offline   Reply With Quote
Old 03-11-2013, 10:52 PM   #37
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i have played with every single air blowing mode and the AC turns on every freaking time... sigh...
for those of you who don't have the AC automatically turn on everytime you turn on the air, do you select the mode first and then switch the dial, or switch the dial then the mode?
chenshuo is offline   Reply With Quote
Old 03-11-2013, 11:17 PM   #38
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
I turn my car on, every time, and the AC does not automatically come on. It has my previous settings from the last time I drove. I think there is something wrong with your Climate Control. And yes I have a Limited BRZ.
Old 03-11-2013, 11:22 PM   #39
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
OK here is what I've seen with my BRZ Limited.
Full Auto...a/c light will be on. If needed a/c compressor will kick in to cool off cabin. If really warm the recirc light will come on but then turn off once temp is maintained at setting.
When outside temps fall below 32* F the a/c light will turn off. I guess this way the cmpressor won't turn on. Once outside temp raises to 32*F and above the a/c light will come back on. Mind you that this is with the full auto setting.
At any time you can switch off the a/c light manually. This turns off the full auto icon. On my car the a/c light will stay off when turning car off and then restarting. The a/c will never come on by itself in the manual mode.
I know this sounds confusing...
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 03-11-2013, 11:23 PM   #40
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
no i didn't say that the AC turns on when my car is on, i mean when i turn the fan speed dial then the AC turns on, everytime.
Old 03-11-2013, 11:40 PM   #41
Khazzy
Khazzy's Avatar
Sorry, my misunderstanding. My comment still stands though, I do not have that issue. Even when I click the AC button, the fan speed is still at what I had it set to.
Old 03-11-2013, 11:41 PM   #42
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
and this is why I bought a premium
eikond is offline   Reply With Quote
climate control swap possibility Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 143 03-15-2019 12:46 AM
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 09:38 AM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 09:03 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 06:34 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 10:19 PM
