Old 11-06-2012, 12:37 PM   #1
cantaloupe
Drives: brz
Auto Climate Control turns on randomly
Anyone else encounter this issue? The ac will randomly turn on even though I know I turned it off. Happened a couple times and thought I was going crazy. Never seen this issue until this morning.
cantaloupe is offline   Reply With Quote
Old 11-06-2012, 01:25 PM   #2
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Do you have it set to "auto"?
Used the front defroster? I know in most cars, the front defroster (defogger?? Whatever) will use the AC - and in some cars when you switch the controls back to vents, the AC will stay on. Not sure how this one works offhand.
ashtray is offline   Reply With Quote
Old 11-06-2012, 01:27 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
AC will turn on automatically in certain car when at the windshield defroster settings. Not sure about the FR-S yet.
Rayme is offline   Reply With Quote
Old 11-06-2012, 02:19 PM   #4
cantaloupe
Drives: brz
Nope, I pressed the "off" button then only hit the recycled air button. Couple minutes later, the ac will turn on by itself. Will do some more testing later.
Old 11-06-2012, 02:29 PM   #5
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Happens to me all the time also. Was wondering the same thing. I knew about it turning on for the defroster but I know for certain that it has come on when I haven't used it at all.
rapidcars is offline   Reply With Quote
Old 11-09-2012, 03:52 PM   #6
Lytheum
Drives: 2013 BRZ Premium 6MT
i know in my mazdaspeed 3 the a/c would cycle the compressor no matter what setting you had it on. it was normal with the auto climate control.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 11-09-2012, 10:20 PM   #7
Longhorn248
Hook 'em
Longhorn248's Avatar
This makes me glad that I have to turn a dial in order to run my A/C.
Longhorn248 is offline   Reply With Quote
Old 11-09-2012, 10:48 PM   #8
White64Goat
Mine has switched all by itself too. I had the unit set to 70 degrees last weekend and the vents set to feet & face with the blower set to the second speed. When I went to leave later in the day I noticed the vents were now on feet and defrost, the 'auto' was lit up and the fan speed was now at 3. Haven't had time to read the owners manual fully yet....
Old 11-10-2012, 07:47 AM   #9
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
I'd be happy to help out, research the owner's manual, and determine if there is a solution there, BUT, I have the manual system (Premium model) and it does what I tell it to do , no exceptions.
BRZfan is offline   Reply With Quote
Old 11-10-2012, 09:27 AM   #10
Turbowned
Turbowned's Avatar
RTFM, you should hopefully understand then. The system is designed to make temperature control easier, not harder, I promise you. I'ts not new tech, either. My friend's 1990 Supra has auto climate control. My Mercedes is always set to 72; set it and forget it.
Old 11-10-2012, 09:31 AM   #11
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
OK...here is my take on this. There are two auto functions. The first is a full auto and is selected by pushing the auto button. You will then see the auto indicator in the display go to a highlighted display.
In full auto the climate control has full control of the system to maintain the set temp. It will select the fan speed, air direction, a/c compressor and the recycle funtion
Now...if you turn off the a/c by toggling the a/c switch the system is still in a reduced auto function and this is shown by the auto indicator now being just the word auto and not highlighted.
In this mode the system will still select fan speeds and direct air flow. Hence the changing settings.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 11-10-2012, 12:44 PM   #12
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Strange. I hit Auto and then the AC button and it stays off.
Old 03-12-2013, 07:51 PM   #13
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
is there a way to change the "reduced auto" function to not-auto? i my A/C always turn on when i turn on climate control no matter what air flow setting i set.
chenshuo is offline   Reply With Quote
Old 03-13-2013, 08:50 PM   #14
BMWDavid
Not sure what you are saying...but if you set the air direction (floor, face, etc) on my car it will still try to mainatin the temp via fan speed and if the a/c is toggled on it will cycle the compressor.
Now...if you manually set a fan speed I've seen the fan speed increase to try and overcome a large temp delta between temp setting and ambient.
This is how my car acts.
2005 Honda XR650L
2006 VW GTI/DSG
You guys with Limiteds, hows your climate control working? houseofsuffering BRZ First-Gen (2012+) — General Topics 58 02-22-2013 08:37 AM
Climate control Panel for the FRS. Mrqb22 Electronics | Audio | NAV | Infotainment 6 02-13-2013 08:03 PM
Climate control bezel Surok AUSTRALIA 7 10-25-2012 05:34 AM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
Launch Control on Auto? devinclfalcons Engine, Exhaust, Transmission 28 03-01-2012 07:14 PM
