Old 01-05-2013, 04:48 AM   #29
ThaBigUnit
Awesome Member!
ThaBigUnit's Avatar
Drives: 2013 Scion FR-S (Asphalt)
Just installed the red one (in my scion fr-s)...its not that much noticeable...i did pay $40 for the pack, don't think it was worth it to be honest. I'm actually probably going to try and sell the other colors to make some money back
ThaBigUnit is offline   Reply With Quote
Old 01-05-2013, 04:53 AM   #30
slidethis
Drives: Argento
Since theres foam..Did ever think to gut the pipe take the crap out and put it back on..-____-..
slidethis is offline   Reply With Quote
Old 01-09-2013, 12:42 AM   #31
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Installed blue "quiet" one today. Not much noticeable difference at low revs but much quieter at high revs.
I love it. Makes the engine sound much more natural. It's not like the 86 is so soundproofed you need the engine amplified beyond the usual.
Would have been much better if the sound changer went in the upper elbow join and then had a straight pipe into the firewall. That way if wouldn't be so damn difficult to get your hand through to pop it out and back into the firewall grommet.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Pacific (01-09-2013)
Old 01-09-2013, 01:34 AM   #32
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
this FAQ makes the install so easy! Thanks!
ZC6BRZ is offline   Reply With Quote
Old 01-13-2013, 04:51 PM   #33
mrjester
Super simple install. The hardest part was getting the changer out of the tube. Finding it and pulling out/putting it in the firewall was trivial.
So far, I like the blue a lot. It makes the cabin noise much more consistent and doesn't overpower the stereo any more. I have to wonder if there is any purpose to the rest of that hose that comes off the intake or if that could just be removed all together.
mrjester is offline   Reply With Quote
Old 01-13-2013, 07:37 PM   #34
nzer
nzer's Avatar
Yes, the extra bits can be removed.
See the below thread that covers other stuff as well but has a section on removing the piping all together and blocking it off at the start point.
Saw another pic of it somewhere too capped off but can't find it.
On the pulling out - agreed, easy in a LHD car but in RHD a bot more difficult to get your hand to it.
http://www.ft86club.com/forums/showthread.php?t=7975
mrjester (01-13-2013)
Old 01-13-2013, 09:54 PM   #35
mrjester
Great. $17 wasted on the blue changer when I could have spent $5ish and got rid of it all together.
Old 01-13-2013, 11:04 PM   #36
nzer
nzer's Avatar
Yep, and from the other post I have seen on here you can make the loud red one by simply removing all the foam and stuff out of the stock one.
If removing it all together you may want to put a solid grommet into where it slots into the firewall.
Old 01-13-2013, 11:40 PM   #37
J-Money
J-Money's Avatar
Drives: GT-86
I just took mine out and striped everything out from the inside.. sanded the inside down for it to be smoothed put it in. Id say it sounds the same if not +1 then the original.. i do have an exhaust. but i wouldnt buy it. THeres not enough differance
J-Money is offline   Reply With Quote
Old 01-14-2013, 02:23 AM   #38
lazyluka
Drives: GT86
Thanks to nzer I managed to get a red TRD sound tube.
My observation is that it is just a hollow tube. Save your money and just modify your stock one as mentioned in the previous post.
Haven't taken the car for a drive yet so can't comment on noise.
All I can say is that THIS IS A PAIN to install for anyone with a RHD car. You either have to have puny hands or take parts off to be able to put the sound changer back in.
The below advice is mainly for RHD vehicles:
If you find that it's too loud, instead of changing it back over, it is much easier to simply move the carpet, access it from the interior and stuff it full of foam or just seal it up all together. Interior access is easy, engine bay access is a pain.
lazyluka is offline   Reply With Quote
Old 02-11-2013, 03:15 AM   #39
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Would you have the red one i could buy from you?
Minovsky is offline   Reply With Quote
Old 02-11-2013, 12:24 PM   #40
nzer
nzer's Avatar
Sorry, already gave it to a mate
Minovsky (02-11-2013)
Old 02-14-2013, 04:14 PM   #41
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Quick question... You mentioned to just pull the sound tube out from the firewall. Is it really that easy? Just pull it out? Wanted to double check before I pull it out and damage it. Does it just snap back in?
Cajun is offline   Reply With Quote
The Following User Says Thank You to Cajun For This Useful Post:
Minovsky (02-14-2013)
Old 02-14-2013, 04:31 PM   #42
Minovsky
Minovsky's Avatar
^yeah that
The Following User Says Thank You to Minovsky For This Useful Post:
Cajun (02-14-2013)
Installing JDM Window Visors Calidrifter DIY (Do-It-Yourself) Guides 65 07-01-2019 12:25 AM
SARD PCD changer 5x114.3 TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-15-2012 08:34 AM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 02:08 PM
TRD sound changer! Surok Engine, Exhaust, Transmission 2 08-26-2012 10:20 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 07:12 PM
