Old 07-05-2012, 07:31 AM   #1
TuxedoCartman
Drives: '13 86
SARD PCD changer 5x114.3
I noticed quite a few people still seem upset about the 5x100 hubs on the 86/BRZ. If so, then have you seen this?
http://www.sard.co.jp/after/products...k/PCD/PCD.html
Changes it over to a 5x114.3 setup. Not sure how strong it is, though; wouldn't trust it on my car for serious track duty. Still, thought folks in the community might want to know about it.
TuxedoCartman is offline   Reply With Quote
Old 07-05-2012, 08:00 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You can find them from many companies... Probably cheaper than the sard ones
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-05-2012, 08:59 AM   #3
JDMSushi
JDMSushi's Avatar
Drives: JDM86
Project KIKS do a decent 10mm one
http://www.bulletproofautomotive.com...il.php?ID=7481
JDMSushi is offline   Reply With Quote
Old 10-15-2012, 12:51 AM   #4
philstar
philstar's Avatar
Drives: Argento FR-S
with the sard one being only 15mm, and the kiks one being only 10mm, you would still be limited to wheels that allows the stock studs to poke through huh unless any of the kits came with extra short studs.
philstar is offline   Reply With Quote
Old 10-15-2012, 08:34 AM   #5
gmookher
fine for track use
gmookher is offline   Reply With Quote
5x114.3 hub conversion mclevin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-03-2012 09:53 AM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
spacers for 5x114 in australia derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-30-2012 10:03 AM
5x114.3 jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-30-2012 03:12 AM
SARD turbo Kit in September + More! toxicdrift Engine, Exhaust, Transmission 15 04-15-2012 11:35 PM
