Old 08-14-2012, 03:04 PM   #1
SupraLove
Drives: 2007 Toyota Camry LE, 5AT i4
Lightbulb Installing GT86 AC unit?
Can you install the 86/BRZ auto climate control into the FR-S? Is this even possible? If so, what would be necessary to get it installed and working correctly? Has anyone done it yet? Thanks. Sorry for the question bombardment, btw.
SupraLove is offline   Reply With Quote
Old 08-14-2012, 03:06 PM   #2
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I think it's the same as the BRZ Limited unit...yes?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-14-2012, 03:07 PM   #3
SupraLove
Yes, but I wanted to know how it would be installed as it uses a different wiring harness.
Old 08-14-2012, 03:50 PM   #4
sparks
sparks's Avatar
The parts catatlog shows 4 different part numbers for the dash harness. Preimum AT & MT, Limited AT & MT
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 08-14-2012, 04:09 PM   #5
Superhatch
AIM4APX
Superhatch's Avatar
I would guess that the wiring harnesses are compatible and it's a matter of unplugging your AC controls, getting a harness and plugging everything else in...assuming it lines up physically.
I would imagine that the ECU inputs would be the same with just a different input device between the FRS and BRZ. It might be that the BRZ has some different programming in the ECU for AC controls though.
Also...I bet the harness costs a grip.
Old 08-14-2012, 09:18 PM   #6
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Doubtful. The last time I looked into an Auto Climate Control HVAC swap, it turned out the manual HVAC was vacuum operated and the auto HVAC was servo operated.
Probably cost prohibitive. You're better off buying a BRZ and putting an FRS bumper on it.
LSxJunkie is offline   Reply With Quote
Old 08-15-2012, 12:45 PM   #7
SupraLove
Has anyone actually looked into doing it on this car? That's the whole reason I started this thread.
Old 08-15-2012, 06:12 PM   #8
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
People have looked into it. The answer is that no one knows, because no one has done it yet. Given that the car is made by Subaru, you probably would have to get a whole new wiring harness, because Subaru makes theirs model specific 1 piece.
ZC6BRZ is offline   Reply With Quote
Old 08-15-2012, 06:14 PM   #9
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Actually, for Subaru, you usually have to replace the WHOLE harness from ECU to battery to tail lights. They usually are trim specific, and if it doesn't have an option, the harness isn't produced to support it.
Old 09-07-2012, 12:35 PM   #10
lupehoops26
lupehoops26's Avatar
Drives: 2007 Tacoma / 2008 Kawi EX500
Don't be a sellout! Real sports cars don't have modern conveniences such as automatic climate control! I kid. No, but really.
-the open road is home
lupehoops26 is offline   Reply With Quote
Old 09-07-2012, 02:08 PM   #11
kndonlee
I was looking into this a while ago and starting going through the electrical diagrams. Replacing the whole harness is well probably something most wouldn't trust themselves doing.
The trick would be to build a convertor harness that would provide the additional connections necessary, however Subaru doesn't sell just ends, thus the whole harness would probably be necessary. The next question is, why not purchase a harness and just use the appropriate parts? The harness in question runs about $800 ish. So that's a pretty penny to pay for donor connectors.
I suppose the most cost-effective way to do a swap would be to get the appropriate wiring connections out of a BRZ limited.
kndonlee is offline   Reply With Quote
aircon, brz, climate, control
Installing BRZ Trunk Interior Liner into FR-S DarrenDriven DIY (Do-It-Yourself) Guides 30 11-19-2016 02:06 AM
DIY: Alarm installing wiring diagram trueno86power DIY (Do-It-Yourself) Guides 17 02-07-2014 09:03 PM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 07:12 PM
Installing a Galaxy Nexus ? Ideas ? miodculae Electronics | Audio | NAV | Infotainment 12 07-20-2012 03:36 PM
