Old 08-09-2012, 07:12 PM   #1
hx3
[FR-S] Installing New Subwoofer and Mono Amp
Hey, I'm a newbie on this forum and just bought a silver FR-S two weeks ago...absolutely loving it! Except for the low's from the stock speakers, and I'm a music junkie.
Anyway, I've been doing a lot of searching around, primarily on this forum, in regards to adding a single sub and a mono amp. I haven't found exactly what I'm looking for, but I've come across some useful information. I apologize if this has been discussed already, but I'm really not sure of the steps I should take. I have the stock Pioneer double DIN head unit in my FR-S, which I know has a set of RCA pre-amps in the back.
I'm coming from a Mazda 3 hatch, in which I installed the following with no issues:
Subs: http://www.crutchfield.com/p_2061DC1...22.html?tp=112
Amp: http://www.sonicelectronix.com/item_...11DX500.1.html
Wiring: http://www.sonicelectronix.com/item_...K4-09ZCK4.html
HU: http://www.sonicelectronix.com/item_...KW-R900BT.html (my Scion dealership kept this in my trade-in, as I misplaced the OEM receiver)
Now I know those subs aren't going to fit in the FR-S' trunk and I've read that I should look for a sub that's under 14" in height. I'll figure that part out easily enough (recommendations are appreciated!). My main concern is the amp and its wiring. I plan on using the same amp as above (which does not need a remote wire connected to the receiver, as it can turn on when it detects an audio signal and turn off automatically) but I'm not exactly sure how I should go about installing everything. I'm aware that there is a two channel amp powering four of the eight speakers, but I also need my Kicker amp to power the sub.
Here is what my ideal solution would be, or at least what I'm familiar with when installing an amp and sub:
  • Four gauge power cable from the amp to battery.
  • Four gauge ground cable from amp to metal under trunk cover.
  • RCA cable from amp to back of the stock Pioneer receiver.
  • Run the power cable on the passenger side of the car and RCA on driver side.
Is that all I should have to do in order to get a new sub working properly or do I need to connect anything to the pre-existing wiring from the rear speakers and/or receiver? The stock speaker and receiver setups are a little different than what I'm used to, so I'm just wanting to make sure I take the right steps before installation takes place. My setup's are pretty basic...no extra hardware and whatnot. Just the sub, amp, wiring and stock HU for the time being.
I plan on purchasing a new receiver in the near future once proper brackets and such are released. I'm rather pleased with the speakers, except the lows can sound absolutely horrible at times. Definitely wanting to move the bass setting to "0" or below and rely on a new sub for the lows.
And, just in case, does anyone have any sub recommendations? I'm looking in to any combination that could fit in the trunk with some room left horizontally and would work with that Kicker 500w amp at 2 ohms (or 275w at 4 ohms).
Any help is greatly appreciated! I apologize for the long post. I just wanted to be clear with my setup and all. I look forward to visiting this site/forum everyday!
hx3 is offline   Reply With Quote
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Installing BRZ Trunk Interior Liner into FR-S DarrenDriven DIY (Do-It-Yourself) Guides 30 11-19-2016 02:06 AM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
Installing a Galaxy Nexus ? Ideas ? miodculae Electronics | Audio | NAV | Infotainment 12 07-20-2012 03:36 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 12:05 PM
