Old 12-09-2012, 10:48 PM   #15
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Originally Posted by Mo707 View Post
Do you gain/loose performance from this?
nope. it just changes the sound in the cabin
86_ZN6 is offline   Reply With Quote
Old 12-09-2012, 11:11 PM   #16
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
I presume it still makes an audible difference with an aftermarket intake?
ill86 is offline   Reply With Quote
Old 12-10-2012, 12:12 AM   #17
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I've got an aftermarket intake and exhaust that generate their own sounds but the sound tube generates another audible roar on top of all that. I know it does because when I disconnected the sound duct and plugged the hole in the firewall, that roar went missing.
The Following User Says Thank You to switchlanez For This Useful Post:
ill86 (12-10-2012)
Old 12-10-2012, 07:56 AM   #18
Thobjo
Drives: GT86
Still seems like an easy DIY to me, thanks for the info.
Thobjo is offline   Reply With Quote
Old 12-11-2012, 08:35 AM   #19
jm1681
Drives: MKVI VW GTI
Originally Posted by Killerbee View Post
Any chance you can take some measurements? Seems like an easy make-your-own mod
jm1681 is offline   Reply With Quote
Old 12-11-2012, 09:16 AM   #20
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Sure, if you let me know what measurements you're actually interessted in?
Otherwise, it really just takes 10 Minutes to unistall/reinstall the stock sound tube, so if you wanna make a copy of it it may be easier to use the stock one as reference.
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
jm1681 (12-11-2012)
Old 12-11-2012, 11:27 AM   #21
jm1681
Drives: MKVI VW GTI
Oh duh >.<
Good call, thanks XD
Old 12-22-2012, 01:26 AM   #22
Timtamtt
Timtamtt's Avatar
How much were they?
Timtamtt is offline   Reply With Quote
The Following User Says Thank You to Timtamtt For This Useful Post:
invaliduser (02-17-2013)
Old 12-27-2012, 02:10 AM   #23
Killerbee
Killerbee's Avatar
Originally Posted by Timtamtt View Post
How much were they?
Depends a bit where you buy it. I ordered mine over ebay directly from japan, had them 3 days later in my mail, but payed about 110 usd.
some others in this forum mentioned some local dealer that could organize them for about 60 usd.
Old 12-27-2012, 02:22 AM   #24
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
ouch. $110? Retails for JPY 2940 = USD 35. EMS is painful.
ZC6BRZ is offline   Reply With Quote
Old 12-31-2012, 10:05 AM   #25
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
^^ Yeah true, but I like getting packages from Japan once in a while
CircuitJerk is offline   Reply With Quote
Old 01-03-2013, 07:21 PM   #26
Xdragonxb0i
Drives: ex500r
Ouch talk about a pricey/Ricey mod!
This mod is just to "enhance" the drivers experience by making the cabin louder.
But I would much rather spend that $65-110 dollars on aintake that normally will make your car sound louder plus there are some performance gains. I think I will go to the sound generator delete dyi route.
Xdragonxb0i is offline   Reply With Quote
Old 01-04-2013, 07:42 AM   #27
Killerbee
Killerbee's Avatar
thats ok when you live in a country that this is street legal. Over here, we either cant buy an aftermarked intake for under 350USD minimum, nor drive it street legal. The fine if police catches you with an modified intake the first time is at least 300 USD, secound time it will be around 1000 USD etc.
Old 01-05-2013, 04:27 AM   #28
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Thanks for this @Killerbee
It's a bit trickier to install in our RHD cars as is on the other side (away from the battery) and has more "stuff" in the way.
So, for those with RHD cars (UK, Australia, New Zealand etc) here's a DIY written by @Nafe
Link is here http://www.ft86club.com/forums/showp...6&postcount=32
Originally Posted by Nafe View Post
@nzer
Ok dude, so I have never written a DIY guide before, but here goes :P
You will need a pair of pliers, a rachet and 12mm socket.
1. First removed the right hand (drivers side) strut bar but removing the 3x12mm nuts and 1x 12mm bolt.
2. you need to access the first joint in the sound generator system, after the generator itself. refer diagrams. The pliers are required to move the clip out of the way, and then pull the hose off as gently as you can, as not to damage anything.
It is in the highlighted area, but just out of vision:
Here is a close up, the first pic ws to show you the area to look
Move the clip that the arrow points at.
Removing this join makes the rest easier. This isn' the part you replace with the TRD part.
3. The fiddly part is coming up now. The hose/sound tube now enter the cabin through the firewall. It is quite literally underneath the steering column. It is impossible to really see, so just follow the hose with your fingers. The picture below highlights the area it is in. After removal, feel for the grommet in the firewall. This is only to help you get a better idea of where it is, do not remove the grommet.
4. Now remove the grey sound tube from the hose. Take not as to how it is fitted, as you will need to fit the TRD part the same way. Don't fret, there is a mark on the hose you can line up with the casting seam of the TRD part. I apologise, I haven't got pics of this as I didn't take any while doing it. Kit is quite straight forward, however the sound tube is a bit of a pain to remove :P
5. Feel around again for the grommet to locate it, and refit the tube as close to the original position as possible. You can twist it a little once fitted to line up if required. This was the trickiest bit as you can't see shit!!
6. reassemble other components in reverse order.
7. go for a drive and bask in the awesome cabin noise!!
Hope this is helpful dude
Thanks Nafe!
nzer is offline   Reply With Quote
The Following 2 Users Say Thank You to nzer For This Useful Post:
FT_86_SM_GP (07-02-2014), Killerbee (01-05-2013)
Installing JDM Window Visors Calidrifter DIY (Do-It-Yourself) Guides 65 07-01-2019 12:25 AM
SARD PCD changer 5x114.3 TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-15-2012 08:34 AM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 02:08 PM
TRD sound changer! Surok Engine, Exhaust, Transmission 2 08-26-2012 10:20 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 07:12 PM
