Old 08-10-2012, 07:35 PM   #15
KlafKoon
Drives: 2013 H8R FRS, 03 Miata (Sold)
Originally Posted by phanguy View Post
when i finally getting around to receiving and installing mine i'm just gonna pop the stock mic out and put the new one in the same place so it has the same oem look to it. :P hope it works! cause that's the plan at least...
May not be relavant as I bought and installed a JVC unit, but I routed my mic up to where the oem mic is located as well. Popped out the existing mic tried to find some way to have mine behind the oem mic cover. Sadly my mic is somewhat akwardly shapped and can't really fit in cleanly. So the mic is attached to the old mic to hold it in place. The one person i've called said that all they heard was wind(you may have more luck). So i've resorted to just popping off the cover and having the mic stick out from the top lining when make/recieve a call until i can find a more permanent solution for it.
And in regards to gps antenna location. I stuck mine behind my headunit on the metal bar and it hasn't had any issues with getting reception (but again, different unit). So it may be a clean solution if people that don't want to stick it under the windshield on the dash or route it around to another location in the car.
KlafKoon is offline   Reply With Quote
Old 08-30-2012, 10:54 AM   #16
encity5
encity5's Avatar
Originally Posted by jimgfl View Post
Trying in install a Pioneer AVIC X940BT having problems with wiring. Does anyone know where the Speed sensor wire is on the FR-S? Have to connect the Pioneer Pink Car speed signal input wire to it.
Also there are two orange wires on the Toyota harnesses, one on the big connector and one on the other small connector. Which one do I connect to the pioneer orange wire or do I connect both?
And one last question, where do I connect the blue wire on the Metra - Antenna Adapter?
Thanks!
Ever figure out what the answer is?
encity5 is offline   Reply With Quote
Old 08-31-2012, 02:20 PM   #17
RebornS14
RebornS14's Avatar
Drives: S14K
you want to bypass the speed sensor so you can use the navi/dvd while in motion.
if you dont know how to repin your harness i suggest you order this kit.
http://www.microbypass.com/index.php...od&productId=8
or you can do it yourself. plenty of instructions on you tube. pretty simple to do.
RebornS14 is offline   Reply With Quote
Old 12-20-2012, 03:53 PM   #18
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Originally Posted by Flat Black VW View Post
When I get back to my shop I can try and look up the speed sensor wire for you on direchtechs or installogy(paid subscription wiring sites) for the orange wire, one is positive dimmer trigger one is negative, I might be able to find out which one it is for you but it's pretty easy to find out during install, just Hook up one of them and see if the dimmer switch dims the radio, if not try the other one.
The blue wire on your antennae adapter is a remote wire to tell the antennae to turn on, there should be a blue and a blue/white wire on the radio harness, blue is amp turn on and blue/white is the one you want.
These should work for you, I'm not 100%. I work sales at a car audio shop so I have a good amount of knowledge on this stuff and have done installs before, but I'm not an installer. I can double check with some of my guys when I get back to work but right now I'm sitting at an audi dealer getting a radio code programmed.
Were you ever able to look up the VSS wire and reverse wire? I have the 920bt and already have the override done to that so I can use the speed sensor for more accurate GPS plotting and other features yet still allow my passenger to enter destinations and all that fun stuff.
I am going to try to do my install over the xmas break if I can find the time (And all parts are in since I'm waiting on a backup camera). Anyway, I appreciate the help on the wire locations.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 12-20-2012, 04:23 PM   #19
lordtakuban
Actually, I might have found the answer in another thread:
http://www.ft86club.com/forums/showt...t=speed+sensor
Looks to be pin 17 of the 28 pin harness. Wire color Pink/Green.
I'll post back once I've gotten around to doing the install to verify if that was it or not.
Old 12-21-2012, 01:50 AM   #20
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Yes its the Pink/Green. Same wire I used here: http://www.ft86club.com/forums/showthread.php?t=15239 to bypass the factory nav
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
lordtakuban (12-21-2012)
Old 12-21-2012, 08:05 AM   #21
lordtakuban
Ahh Yes. I remember reading that thread a while back. But I forgot you mentioned and showed the VSS wire so well in that. Thanks again.
Old 12-21-2012, 07:18 PM   #22
rbizzle004
Thanks!
I didnt read through all the posts but Reverse wire should be pin #2 on the 28 harness and the VSS is pin #17 on the 28 pin harness. Pin #9 on the 10 pin harness should be the remote turn on for the factory amp. Power Antenna wire from the HU should hook up to the blue wire from the antenna adapter.
rbizzle004 is offline   Reply With Quote
Old 12-21-2012, 07:22 PM   #23
rbizzle004
See post #20 http://www.ft86club.com/forums/showthread.php?t=24032
For the power antenna and remote wire for factory amp if you have any questions.
Old 12-22-2012, 11:58 AM   #24
lordtakuban
VSS is pin #17. But, on the Scion, there is no wire going to pin #2 in that harness. Which kinda sucks, because that would make setting the new HU up super easy. haha.
Pioneer AppRadio quik1987 Electronics | Audio | NAV | Infotainment 33 01-23-2012 06:55 PM
