Old 08-02-2012, 10:49 PM   #1
jimgfl
Help with after market Pioneer AVIC X940BT
Trying in install a Pioneer AVIC X940BT having problems with wiring. Does anyone know where the Speed sensor wire is on the FR-S? Have to connect the Pioneer Pink Car speed signal input wire to it.
Also there are two orange wires on the Toyota harnesses, one on the big connector and one on the other small connector. Which one do I connect to the pioneer orange wire or do I connect both?
And one last question, where do I connect the blue wire on the Metra - Antenna Adapter?
Thanks!
jimgfl is offline   Reply With Quote
Old 08-02-2012, 11:34 PM   #2
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
i ordered the same one... getting it next week. guess i'll be running into the same issues. hope you get it figured out!
phanguy is offline   Reply With Quote
Old 08-03-2012, 02:15 AM   #3
phanguy
phanguy's Avatar
http://www.ft86club.com/forums/showthread.php?t=13038
and maybe that might help.
The Following User Says Thank You to phanguy For This Useful Post:
jimgfl (08-03-2012)
Old 08-03-2012, 07:42 AM   #4
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Be sure to post if you figure out how to use the stock Mic and USB/Aux inputs with your Pioneer unit. I have a 920bt that I plan on switching over once all the kinks are worked out.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 08-03-2012, 10:03 AM   #5
encity5
encity5's Avatar
for the OEM USB / AUX diy
http://www.ft86club.com/forums/showt...ht=aftermarket
encity5 is offline   Reply With Quote
The Following User Says Thank You to encity5 For This Useful Post:
jimgfl (08-03-2012)
Old 08-03-2012, 11:28 AM   #6
lordtakuban
Thanks. Now all that's left is the microphone.
Old 08-03-2012, 11:53 AM   #7
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
When I get back to my shop I can try and look up the speed sensor wire for you on direchtechs or installogy(paid subscription wiring sites) for the orange wire, one is positive dimmer trigger one is negative, I might be able to find out which one it is for you but it's pretty easy to find out during install, just Hook up one of them and see if the dimmer switch dims the radio, if not try the other one.
The blue wire on your antennae adapter is a remote wire to tell the antennae to turn on, there should be a blue and a blue/white wire on the radio harness, blue is amp turn on and blue/white is the one you want.
These should work for you, I'm not 100%. I work sales at a car audio shop so I have a good amount of knowledge on this stuff and have done installs before, but I'm not an installer. I can double check with some of my guys when I get back to work but right now I'm sitting at an audi dealer getting a radio code programmed.
Flat Black VW is offline   Reply With Quote
The Following User Says Thank You to Flat Black VW For This Useful Post:
jimgfl (08-03-2012)
Old 08-03-2012, 05:22 PM   #8
encity5
encity5's Avatar
Thanks!
What are using to hide the gaps on the sideof the headunit when you install?
Old 08-06-2012, 08:38 AM   #9
Blue86
Drives: Sonic Blue 86GT Manual
http://www.aerpro.com/p.php?pcode=ATB2
or aerpro FP9016 which has a DIN pocket and the side ears too. This would be for a single DIN installation normal head unit or flip out single DIN screen.
Blue86 is offline   Reply With Quote
The Following User Says Thank You to Blue86 For This Useful Post:
encity5 (08-06-2012)
Old 08-09-2012, 07:29 PM   #10
TemeCal
Drives: 86
I'm planning to install the X940BT as well. Anyone have any luck getting the mic to work?
TemeCal is offline   Reply With Quote
Old 08-09-2012, 07:40 PM   #11
phanguy
phanguy's Avatar
when i finally getting around to receiving and installing mine i'm just gonna pop the stock mic out and put the new one in the same place so it has the same oem look to it. :P hope it works! cause that's the plan at least...
Old 08-09-2012, 07:42 PM   #12
TemeCal
Drives: 86
Thanks phanguy! I've subscribed to this thread, so I'll be sure check back.
Old 08-10-2012, 02:12 PM   #13
Chillz
Drives: Asphalt FR-S & S14
Where are you guys installing your GPS antenna?
Chillz is offline   Reply With Quote
Old 08-10-2012, 04:57 PM   #14
Flat Black VW
im not installing one of these on my car, however when I do them at work I usually put them in the front passenger corner of the windshield. This location will work fine for our cars, the only cars I sometimes run into problems with are a few Mercedes and Rovers which have heated front windshields using thin metal strips running through the windshield which can cause some interference.
If you want to put it somewhere else just make sure there is no metal blocking it. I did a radar detector in a customers FR-s about a month and half ago and I was able to put the GPS antennae for that under the rear deck lid and didnt run into any signal problems so that would probably be an option also.
Pioneer AppRadio quik1987 Electronics | Audio | NAV | Infotainment 33 01-23-2012 05:55 PM
