ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Electronics | Audio | NAV | Infotainment
Old 08-21-2012, 06:34 PM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
BRZ Back-up Camera and NAV Bypass SOLVED
So after spending my day off of work at work working on my car I have completed a back up camera and the DVD/NAV/VIM bypass.
If anyone tries this, I am NOT responsible for you blowing up your radio or car, try this at your own risk.
I started with running the backup camera, and was happy to find this perfect grommet for the wire. I will be using this grommet for my passport 9500ci also when I install that.
All the wires were hidden under the trunk cover and run with the factory license plate light wires up to the front of the car. This shows the trunk cover back on with no visible wires.
Camera:
Close-up:
For those wondering, this is a Rydeen Miny camera. I used this since they are the ones we sell at my shop and I trust them, plus I get a very good deal on them.
I used this diagram to determine where the camera pins go:
For the pins I used one of SVXdc's plugs for the 2012 impreza rear camera since we had a few sitting at my shop. I pulled the three wires out of his plug and inserted them in my 16 pin plug. The three wires are Camera +, Camera -, and a simple ground. Heres how they looked in the 16 pin connector:
The black and yellow wires on the end lead to an RCA video input, and the second black one in slot 15 needs to be grounded.
While I was there I grounded the grey wire (parking brake) with the black wire:
This was the beginning of the VIM bypass process.
NOTE: THE GROUNDING LOCATION PICTURED DID NOT WORK, the ground was later moved, but I did not get a picture.
Grounding the grey wire allowed me to watch a DVD with the parking brake disengaged, however I still could not type in an address or use my phone because the VSS(vehicle speed sensor) was letting the radio know I was moving. So, the next step in the VIM bypass was to cut the VSS wire and put it on a switch. The VSS is in pin 17 on the 28 pin connector, on my car it was pink/green. This picture shows the wire cut with the switch wires spliced in:
I tested everything before putting it back together and it seemed to work fine, took a quick break out back of the shop and spotted this bad boy:
Back to work, put it mostly back together and tested again:
Camera works!
Completely reassembled:
The camera automatically comes on when the vehicle is put into reverse.
The words and lines on the screen are there from the factory radio settings and as of now I do not know how to get rid of them, they don't bother me too much though so who cares.
The VIM bypass also worked perfectly, although I couldn't really get any pics of this.
Good luck to anyone else who gives it a shot, both are totally worth it!
Flat Black VW is offline   Reply With Quote
The Following 21 Users Say Thank You to Flat Black VW For This Useful Post:
baldolera (08-24-2012), Bristecom (08-24-2012), cobrabyte (08-24-2012), Floggin Tires (08-21-2012), Gintsuki (11-20-2013), grst1 (08-22-2012), illmatic (08-22-2012), Kimsey47 (08-21-2012), kwood9000 (08-22-2012), monkie (01-12-2013), mou (04-29-2013), quik1987 (08-22-2012), ripper (11-16-2014), RYU (08-22-2012), ShoNUFF (01-06-2013), sparks (08-22-2012), Sportsguy83 (08-22-2012), THEWAKLER (12-18-2013), tripjammer (08-24-2012), TSY (08-22-2012), zoomzoomers (08-21-2012)
Old 08-21-2012, 06:48 PM   #2
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
what, they totally should have put the back up camera to begin with! Do the lines change when your steering wheel rotates?
mechaghost is offline   Reply With Quote
Old 08-21-2012, 06:50 PM   #3
Flat Black VW
no unfortunately not
Old 08-21-2012, 07:08 PM   #4
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
Awesome job! This is a high priority on my list of things to do to my BRZ. I hope somebody puts out a reasonably cheap kit for this soon. As I'm not so technically inclined as you are I'll have to find a shop to do the work.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 08-21-2012, 07:44 PM   #5
xwd
Sweet. I was in contact with SVXdc and he was going to do some R&D on my car since we live near each other but I guess you got it figured out.
Why couldn't you just use his harness? Are the pin locations different on the BRZ Nav unit?
Old 08-21-2012, 08:05 PM   #6
Flat Black VW
The harness I had from him was a 6 pin for different nav radios. I simply used it for the pins with the RCA input.
Old 08-21-2012, 08:12 PM   #7
green_comet
green_comet's Avatar
Drives: Ford Focus ST
Nice work, here's hoping someone does a detailed step by step install guide on this, including what parts are needed.
green_comet is offline   Reply With Quote
Old 08-21-2012, 08:18 PM   #8
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Dope!
TouchMyHonda is offline   Reply With Quote
Old 08-21-2012, 09:01 PM   #9
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Nicely done.
Post this here > http://www.ft86club.com/forums/forumdisplay.php?f=43
Halla @DarrenDriven
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 08-21-2012, 09:56 PM   #10
Flat Black VW
Originally Posted by Floggin Tires View Post
I didn't put it there since its not a very detailed write up. There is a lot more to the install than I showed.
If the mods deem it good enough to be a DIY feel free to move it
Old 08-22-2012, 12:13 AM   #11
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
Did you have to wire it to the shifter or is it already pre-wired? Do the JDM cars have back up cameras?
Nice work- I'd love to have a back up camera on my BRZ! I'm going to have to look into getting this done myself.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 08-22-2012, 12:25 AM   #12
Flat Black VW
I did not have to wire it for the shifter. These NAV radios are pretty much set up to add a back up camera.
Old 08-22-2012, 01:02 AM   #13
TSY
TSY's Avatar
That's what I figured. You'd think it would be an option since it's just hooking up an inexpensive little camera.
Thanks again!
Old 08-22-2012, 01:13 AM   #14
zoomzoomers
I'm personally waiting for the JDM parts to be available here in the US. Then it should be entirely plug and play. Just hope it won't cost and arm and a leg. Here's hoping the wait will pay off. Cheers to you for taking your own route! :happy0180:
Search this Thread:
Advanced Search
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Name that spoiler! (SOLVED) WingsofWar Photos, Videos, Wallpapers, Gallery Forum 70 12-06-2014 02:22 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 04:41 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 08:00 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 01:56 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
