#15 | |
Drives: 2013 H8R FRS, 03 Miata (Sold)
And in regards to gps antenna location. I stuck mine behind my headunit on the metal bar and it hasn't had any issues with getting reception (but again, different unit). So it may be a clean solution if people that don't want to stick it under the windshield on the dash or route it around to another location in the car. |
#16 | |
Encity's Firestorm MT Car Journal:
http://www.ft86club.com/forums/showthread.php?p=252545 |
#17 |
Drives: S14K
you want to bypass the speed sensor so you can use the navi/dvd while in motion.
if you dont know how to repin your harness i suggest you order this kit. http://www.microbypass.com/index.php...od&productId=8 or you can do it yourself. plenty of instructions on you tube. pretty simple to do. |
#18 | |
Drives: 2013 FRS - Whiteout
I am going to try to do my install over the xmas break if I can find the time (And all parts are in since I'm waiting on a backup camera). Anyway, I appreciate the help on the wire locations.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified |
#19 |
Actually, I might have found the answer in another thread:
http://www.ft86club.com/forums/showt...t=speed+sensor Looks to be pin 17 of the 28 pin harness. Wire color Pink/Green. I'll post back once I've gotten around to doing the install to verify if that was it or not.
#20 | |
Drives: 2013 Subaru BRZ
| The Following User Says Thank You to Flat Black VW For This Useful Post: | lordtakuban (12-21-2012) |
#21 | |
#22 | |
#23 |
See post #20 http://www.ft86club.com/forums/showthread.php?t=24032
For the power antenna and remote wire for factory amp if you have any questions. |
#24 | |
| Pioneer AppRadio | quik1987 | Electronics | Audio | NAV | Infotainment | 33 | 01-23-2012 06:55 PM |
