| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#449 |
Drives: Whiteout FR-S
The rims fit fine without spacers its the Brembo big brake kit that could cause the problems. Why do you feel you need front and rear Brembo kits exactly?
#450 |
Drives: Scion FRS (Asphalt)
#451 |
Brakes are not my area of expertise but that's a ton of money to spend for more even braking, i think you should do some more research in the brake threads and see if that's really what you need. Even if you put a big brake kit on the rear you would have to be able to change the brake bias also, just doesn't sound like a good idea to me honestly.
#452 |
I'll look more into the rear, but the same info applies to the front as well.
#453 |
Kouki-Monster
Alright here's the setup. I'll be running 18x9.5 +38 all around. I want to run a square tire setup as well.
Some people have done 225/40 which is too much stretch for me. I have done that on a car before and it looks awful unless the car is slammed. I am tossing around 3 tire sizes right now: 235/40/18 245/40/18 245/35/18 I will not go wider in section width as it's simply overkill for this NA car. The other factor that may be the difference between running a 235/40 and a 245/35 is the tire style. I may run something with a larger shoulder block that will fill out the rim more. What say you?
Rich Anderson
EMPOWER AUTO |
#454 |
Lots more tires to choose from in 235/40 than 245/35, 235/40 is usually a lot cheaper too. 245/40's look like too much tire to me on the ones i've seen.
#455 | |
Overall diameter is on par with OEM sizing as well. |
#456 | |
Site Moderator
Drives: Stuff
Your biggest issue now is determining whether or not the wheels will fit over the brakes, as it's easy to find wheels that just fit on the stock car. If the spokes don't go out at a sufficient angle from the hub part of the wheel and stay out before coming back to the rim portion of the wheel, they may not fit over the brembos even though they fit on the car with stock brakes perfectly.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | kurbkilla (11-28-2012) |
#457 |
Drives: '15 STi Ltd
I made a spread sheet a while ago for a "quick -n- dirty" comparison of overall diameters for different size/combos. You should make one (or I'll post a pic).
#458 | |
Kouki-Monster
Heck I can even get a Kumho XS in that sizing but I'd burn through them in no time at all. Thanks kindly... 245/35 was my initial thought.
Rich Anderson
EMPOWER AUTO |
#459 | |
For example on a S2000, the Prodrive GC-07C 17X8.5 +54 are known to have great clearance and can clear most BBKs. While a Enkei RPF1 17x9 +35 wouldn't clear many BBKs. Just by looking at the sizes and offset you would assume the RPF1 would be the better bet. Same can be said about are car with RPF1 17x8 +45 vs 17x9 +35. The 17x8 +45 can clear more breaks as well. |
#460 |
Drives: Scion Fr-s
Rota grids
Ok y'all I've tried to figure this out but can't. Looking to order rota grids for my car. Preferably 18x9.5. My car is lowered on eibach sportlines. What offset do I need and what tires will fit well. I want to be as flush as possible.
"CulbyJack" |
#461 |
86-75309
Drives: Toyota FR-S
Please see Do Boy's FR-S http://www.ft86club.com/forums/showthread.php?t=8403
#462 |
Drives: Scion Fr-s
Ya I found it. Oops. Sorry
"CulbyJack" |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
