Old 10-04-2011, 06:37 AM   #1
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
Determining the proper width size of the tire
How would you go about determining the perfect width of the tire in the front/rear relative to your application and power of the car.
I'd imagine for a car like this going any wider than 8inches in width would be too much unless you're hitting 330+hp.
I'm thinking a 7 inches in the front and maybe 8 inches in the back.
However, I have a feeling this car will come stock at 7 inches front and back.
CyberFormula is offline   Reply With Quote
Old 10-04-2011, 07:55 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Staggered is fine if the suspension is setup or it (ie setup for oversteer). If not having a traction bias in the rear is going to mean understeer. I'd wait until you were traction limited due to power then change rear tires and then change springrates/sway bars/alignment etc
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-04-2011, 11:45 AM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's not fully true. I used to know one Mx5 that was only 200whp-ish and using 9" on the rear and it was perfect size (don't oversteer or understeer). Like Dave state, it's all up on suspension setup.
Old 10-04-2011, 11:51 AM   #4
Fortunate Few
will photoshop for ft86
Fortunate Few's Avatar
Drives: 07 Mazda RX8
Send a message via AIM to Fortunate Few
I'm not gonna be staggered unless the car comes staggered.
Fortunate Few is offline   Reply With Quote
Old 10-04-2011, 12:28 PM   #5
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
+1
I'd rather keep it simple, hopefully Toyota agrees.
no_name is offline   Reply With Quote
Old 10-04-2011, 12:33 PM   #6
suprachica79
Drives: free Hyundai, 2006 Kawasaki ZX6R
Originally Posted by no_name View Post
+1
another +1. I like the look of staggered, but I think it's overkill unless I make some serious HP in this car, anything near stock I think should be kept the same, alot of engineering went into this car, and I trust that Tada-san and his cronies know more about correct engineering than I do
suprachica79 is offline   Reply With Quote
Old 10-04-2011, 12:41 PM   #7
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Id agree that 7 all around in stock form should be ok, but it wont take much more power to reach the limits of that size. I would probably get rims to accomodate future plans.
chulooz is offline   Reply With Quote
Old 10-04-2011, 12:45 PM   #8
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
With the 370z when you upgrade to the 19" wheels and tire grip increases from .92g to .98-.99g with the width only increasing by .5. I wouldn't go too aggressive with the width if I wanted to.
SUB-FT86 is offline   Reply With Quote
Old 10-04-2011, 12:47 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
+1
Subaru's PR already said 215/45/17 tires, so they will not be staggered. Since the tires aren't staggered then the wheels won't be either. OEM's tend to fit tires to the correct wheel size provided by the tire manufacturer.
For that size tire the appropriate wheel widths would be 7.0-8.0 for most performance tires. I honestly doubt they'd issue a 17x8 wheel so my guess would be 17x7 all around.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-04-2011, 01:03 PM   #10
oneday
Opinionated
oneday's Avatar
Drives: Something Red
215/45-17? Ugh. Why an oddball size, I wonder? At least mfgs are starting to make some decent tires in this size now...though they can cost more than the larger, more common 225/45-17.
The other factor to consider when contemplating changing tires/wheels is the weight of the package. A car this light (2600ish lbs) and with this amount of power (190ish HP) will definitely feel different with just a 5lb per corner change.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 10-04-2011, 01:24 PM   #11
ichitaka05
Site Moderator
ichitaka05's Avatar
Oddball size? That's common size. I use that size for my DD wheel.
Old 10-04-2011, 02:04 PM   #12
Matador
hashiryu
Drives: Mk4 Supra
Car is built around the tyres, not vice versa.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 10-04-2011, 02:07 PM   #13
suprachica79
I would have preferred 225/45-17 as well but there are enough options for the 215/45-17 that I'll be able to find something.
Old 10-04-2011, 03:03 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
At least there are RE11s, Star Specs, AD08s, RS3s and XSs in that size.. and some closeout R comps that are likely pointless to use at this point..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
What FT-86 wheel size do you want to see on production version? MR2fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 121 08-15-2012 12:57 AM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 10:46 PM
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 05:58 PM
Proper Roll Cage CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2010 03:51 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
