Old 11-28-2012, 12:35 PM   #449
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
The rims fit fine without spacers its the Brembo big brake kit that could cause the problems. Why do you feel you need front and rear Brembo kits exactly?
Old 11-28-2012, 12:38 PM   #450
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
More even braking; I know the majority of the braking is in the front. I would like the option of adding bigger brakes in the rear
kurbkilla is offline   Reply With Quote
Old 11-28-2012, 12:43 PM   #451
JoeBoxer
JoeBoxer's Avatar
Brakes are not my area of expertise but that's a ton of money to spend for more even braking, i think you should do some more research in the brake threads and see if that's really what you need. Even if you put a big brake kit on the rear you would have to be able to change the brake bias also, just doesn't sound like a good idea to me honestly.
Old 11-28-2012, 12:45 PM   #452
kurbkilla
kurbkilla's Avatar
I'll look more into the rear, but the same info applies to the front as well.
Old 11-28-2012, 01:15 PM   #453
empower-auto
Kouki-Monster
empower-auto's Avatar
Smile Let's pick out some tires
Alright here's the setup. I'll be running 18x9.5 +38 all around. I want to run a square tire setup as well.
Some people have done 225/40 which is too much stretch for me. I have done that on a car before and it looks awful unless the car is slammed.
I am tossing around 3 tire sizes right now:
235/40/18
245/40/18
245/35/18
I will not go wider in section width as it's simply overkill for this NA car.
The other factor that may be the difference between running a 235/40 and a 245/35 is the tire style. I may run something with a larger shoulder block that will fill out the rim more.
What say you?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-28-2012, 01:51 PM   #454
JoeBoxer
JoeBoxer's Avatar
Lots more tires to choose from in 235/40 than 245/35, 235/40 is usually a lot cheaper too. 245/40's look like too much tire to me on the ones i've seen.
Old 11-28-2012, 01:56 PM   #455
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
235/40/18
245/40/18
245/35/18
From those chosen sizes, the 245/35/18 should work out nicely on that wheel spec. Only thing is Tire choices will be limited in this size.
Overall diameter is on par with OEM sizing as well.
Touge Factory is offline   Reply With Quote
Old 11-28-2012, 02:06 PM   #456
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by kurbkilla View Post
The rims (per tirerack's website) will fit with out spacers. If the offset is the same as stock the extra 1/2" in the width wouldn't affect the brake caliper, it would just be 1/2" deeper into the wheel well, right? I just dont see were the spoke pattern effects it other then looks
I'm sure they'll fit the car, but the Brembo calipers most likely stick out further than the OEM ones do, which opens up the chance of caliper to wheel contact. With my AP racing calipers I have to run 10mm spacers to use the stock wheel, and even then it's pretty tight. I only use the OEM wheel as a spare, my 17x8 RPF1s fit fine but 17x9 RPF1s don't because of the spoke design.
Your biggest issue now is determining whether or not the wheels will fit over the brakes, as it's easy to find wheels that just fit on the stock car. If the spokes don't go out at a sufficient angle from the hub part of the wheel and stay out before coming back to the rim portion of the wheel, they may not fit over the brembos even though they fit on the car with stock brakes perfectly.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
kurbkilla (11-28-2012)
Old 11-28-2012, 02:10 PM   #457
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I made a spread sheet a while ago for a "quick -n- dirty" comparison of overall diameters for different size/combos. You should make one (or I'll post a pic).
Chimpo is offline   Reply With Quote
Old 11-28-2012, 02:16 PM   #458
empower-auto
Kouki-Monster
Tire choices aren't bad. Will probably run a Hankook Ventus V12 Evo or Bridgestone RE 760.
Heck I can even get a Kumho XS in that sizing but I'd burn through them in no time at all.
Thanks kindly... 245/35 was my initial thought.
Rich Anderson
EMPOWER AUTO
Old 11-28-2012, 02:31 PM   #459
Hanakuso
Spacers can be used to help with fitment but can put more load on wheel bearings. Spoke design is more important than offset and width by itself (spoke shape).
This is very true.
For example on a S2000, the Prodrive GC-07C 17X8.5 +54 are known to have great clearance and can clear most BBKs. While a Enkei RPF1 17x9 +35 wouldn't clear many BBKs. Just by looking at the sizes and offset you would assume the RPF1 would be the better bet.
Same can be said about are car with RPF1 17x8 +45 vs 17x9 +35. The 17x8 +45 can clear more breaks as well.
Hanakuso is offline   Reply With Quote
Old 11-28-2012, 03:14 PM   #460
gmanculb
gmanculb's Avatar
Drives: Scion Fr-s
Rota grids
Ok y'all I've tried to figure this out but can't. Looking to order rota grids for my car. Preferably 18x9.5. My car is lowered on eibach sportlines. What offset do I need and what tires will fit well. I want to be as flush as possible.
"CulbyJack"
gmanculb is offline   Reply With Quote
Old 11-28-2012, 03:27 PM   #461
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
Please see Do Boy's FR-S http://www.ft86club.com/forums/showthread.php?t=8403
Got3n is offline   Reply With Quote
Old 11-28-2012, 03:28 PM   #462
gmanculb
gmanculb's Avatar
Drives: Scion Fr-s
Ya I found it. Oops. Sorry
"CulbyJack"
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
