NW Region Moderator
Drives: FR-S No More
Correct tire width for each wheel width
Hey guys, I am improving the Wheel Directory topic once again with another tidbit for new wheel buyers.
I need to know the correct tire width for a flush fitment for each wheel width. WHEEL (inches) = TIRE (mm) 7.0 = 215 7.5 = 225 8.0 = 235 8.5 = 245 9.0 = 255 9.5 = 255 10.0 = 265 I could probably look it up, but I am crazy busy and I know that some of you have this information handy... or have some extra time.
Drives: '22 BRZ
there is not a clear cut answer for this.
you should be looking at section width (sidewall to sidewall) and what width wheel it was measured on. it will marginally change with changes in wheel width. a 215mm tire will not always be 8.46" high performance tires tend to be wider than size would indicate. |
Kouki-Monster
I have 215 Cooper RS3's with big shoulder blocks on the front of my car, and the stock 215 Michelin Primacy's on the back. The fronts fill out way better. (look better too)
Rich Anderson
EMPOWER AUTO |
#4 | |
Reap the BReeZe
Drives: 04 LandShark STi
There may be some general rule of thumb, but it's mostly going to depend on the rim width range of a specific tire.
http://www.tirerack.com/tires/tirete...e.jsp?techid=7 Quote:
Oversteer > Understeer
Drives: GT86
This is a very subjective aspect of wheel/tire fitment. Some people prefer a somewhat stretched look, some people like a bulgy look, and some people like it to be "square" (like me!). Another thing to think about is that most "track" tires have oversized treadwidths (i.e. a 215 Hancook RS-3 has the tread width of a regular ol' 225, maybe even a 235).
In general, I would say: 7 =215 8 = 225-235 9 = 245-255 (9.5 would be perfect for a 255) |
Drives: 2013 Subaru BRZ WR Blue Pearl
I have 18"x8" and 245/35s fit perfect on them
NW Region Moderator
Thanks Entropy... I'm looking for a square-fitment guideline that I can post for people who are clueless and need to order tires. I'll put your numbers in the first post and see if anyone wants to argue about it.
NW Region Moderator
I went with this... anyone want to improve the accuracy?
Official Cobb beer knurd
Drives: 2013 BRZ-L MT SWP
That looks about right as a mid-point number based on what I've been looking at for Goodyear performance tires and their fitment ranges.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
#10 |
Running in the 90s
Drives: 2014 Scion FR-S Monogram
It can differ based on Diameter and Aspect Ratio.
Using Yokohama Advan AD08's as an example tire... 225/45-17 would like a 7.5" wide wheel 225/40-18 would like an 8" wide wheel Both 225s, but with different wheel width rec's. It could also differ from manufacturer to manufacturer, but maybe separate lists for 17s and 18s is in order?
藤原とうふ店(自家用)
MattR's Tofu Runner |
#11 |
NW Region Moderator
That is not a bad idea... but I will word this as a guideline only and not a definitive definition of which tire is "correct". If we suggest 17's and 18's then we need 16, 19 and 20?
Maybe it is just too complicated to even provide a guideline? I figured something simple would help newbs feel better about their wheel and tire sizing -- even if it isn't absolutely perfect.
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| WTB: 1 OEM wheel with or without tire | #87 | Wheels and Tires | 11 | 01-31-2013 01:21 AM |
| Track width | -max- | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 08-21-2012 06:37 PM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
