Old 10-05-2012, 02:35 PM   #15
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by jm1681 View Post
Sweet ^_^
Hoping to have it made today, and on the car tonight. Oh, any chance anybody knows the size of the opening for the intake resonator beneath the elbow? Might as well eliminate both while we have the lathe setup XD
Here you go. Exact dimensions for the plugs I machined.
http://www.ft86club.com/forums/showthread.php?t=13696
Old 10-05-2012, 06:21 PM   #16
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Thanks for the dimensions. I went the cheap route, went to home depot with your numbers and found two plugs that match (1 1/2" test plug and 1/2" plumbing screw-type plug) and removed the noise generator. I'll probably do something better looking in the future, but for now, I'm just seeing if I notice a difference.
Old 10-09-2012, 03:53 PM   #17
jm1681
Drives: MKVI VW GTI
Here are the plugs I ended up with Hopefully swapping them out tonight
jm1681 is offline   Reply With Quote
Old 10-09-2012, 03:58 PM   #18
neutron256
neutron256's Avatar
They look great!
Old 10-09-2012, 06:25 PM   #19
jm1681
Drives: MKVI VW GTI
Thanks
Came home after BEATING my car, and was thinking, it's the intake side; it's probably nowhere near as hot as I think it is. Sure enough, opened the hood, and wrapped my hand around the intake pipe.
Warm at best.
Not too worried about melting, now I just need the stupid rain to let up so I can actually DO the swap >.<
Old 10-09-2012, 06:36 PM   #20
neutron256
neutron256's Avatar
Thanks
Warm at best.
It looks like Delrin. Could be ABS or Nylon, but all of them should be up to the task.
The Following User Says Thank You to neutron256 For This Useful Post:
jm1681 (10-09-2012)
Old 10-10-2012, 12:48 PM   #21
jm1681
Drives: MKVI VW GTI
Pulled the noise generator during lunch. I didn't have a lot of time, so I couldn't really get it to temp and romp on it, but it's EASILY quieter than before. Like a LOT quieter.
I can hear the exhaust now, albeit it's still quiet, but I can hear it. I didn't realize just how much noise that tube was making. It's still wet and nasty here, but I'm thinking I'm going to tape off the diaphragm for now (I removed the one tube altogether), and if I decide to switch back, at least I don't need to re-run all of the hoses, just pull the tape and throw the hose back on.
Hoping to get the resonator plug in tonight.
Old 10-12-2012, 04:31 PM   #22
RedLeader
RedLeader's Avatar
So you pulled the tube off and didn't plug either open end? That could be very very bad, as you're sucking in unfiltered air into your engine.
Sent from...somewhere?
Old 10-12-2012, 04:38 PM   #23
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
My being one that doesn't have a lathe nor know any one that does, I will start checking ebay on a regular basis. I don't think it will be too long before someone will have a kit available for doing this and I'll surely grab it up.
whaap is offline   Reply With Quote
Old 10-12-2012, 05:23 PM   #24
neutron256
neutron256's Avatar
There is a kit. $30
http://www.ebay.com/itm/Scion-FR-S-I...83f021&vxp=mtr
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
iBRZ (11-09-2012), whaap (10-12-2012)
Old 10-12-2012, 05:44 PM   #25
whaap
whaap's Avatar
Wow. That was fast! Thanks.
Old 10-12-2012, 09:49 PM   #26
jm1681
Drives: MKVI VW GTI
No, I pulled the noise tube off and plugged the hole with the plug my friend made for me
Pulled the resonator that night and plugged it as well
Really liking the sound the car makes now, and I'd swear the throttle response is a bit more "unfiltered" It feels even sharper and more immediate now
Old 10-12-2012, 10:48 PM   #27
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I have the rubber plug from the Dynosty kit available if somebody just needs that part.
Old 10-13-2012, 07:10 AM   #28
jm1681
Drives: MKVI VW GTI
Where does that go? Directly into/onto the firewall?
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Noise Generator Delete for $10.00 xcelir8brz Engine, Exhaust, Transmission 85 11-23-2014 01:39 PM
Noise Generator Delete Plug Dimensions neutron256 DIY (Do-It-Yourself) Guides 26 04-01-2013 12:16 AM
keeping the noise generator with turbo! Silverdub Forced Induction 11 09-27-2012 01:22 AM
Firewall Plug for noise generator Uniquedetail Engine, Exhaust, Transmission 5 09-19-2012 09:16 PM
