Old 10-02-2012, 02:10 PM   #1
jm1681
Drives: MKVI VW GTI
Noise generator plug material?
So a friend at work offered to spin me a noise generator plug, but we only have two types of material that seem viable.
Aluminum of questionable grade/durability, and white plastic of questionable grade/durability :/
I'm not so much worried about them crushing or breaking, but of possible melting, and in the case of the aluminum, just plain frailty. We make woodworking tools out of the aluminum we use, but it's still very soft stuff. If you slide it along a sheet of paper, it leaves all manner of marks, and even wiping it down with a paper towel will turn the towel black.
The plastic seems pretty soft, but again, it goes into woodworking machine parts. I worry about melting, but I can only imagine in application, it gets pretty hot. How hot do you think that plug will get under there?
I guess the question is, if you had access to the facilities and materials I do, would you feel safe making plugs with those materials?
jm1681 is offline   Reply With Quote
Old 10-02-2012, 02:17 PM   #2
CBR600RR
Drives: Raven Black
Both will work fine; and the aluminum is far from frail - especially in comparison to the mentioned plastic.
Think of all the other plastic under the hood. The part itself which you are plugging is made of plastic.
You will have no melting or frailty issues.
Old 10-02-2012, 02:27 PM   #3
jm1681
Drives: MKVI VW GTI
Originally Posted by CBR600RR View Post
Think of all the other plastic under the hood. The part itself which you are plugging is made of plastic...
Duh, that's a really good point XD
I just figured with all the different grades of things out there, better safe then sorry
Old 10-02-2012, 02:41 PM   #4
CBR600RR
Drives: Raven Black
Always better safe then sorry :-) In this case you are safe to use those materials.
Old 10-02-2012, 02:49 PM   #5
jm1681
Drives: MKVI VW GTI
Just got confirmation, the plastic is Delrin. Basically, the same stuff they make guitar picks out of It's hard to describe the stuff, but if you saw it, you'd probably understand my apprehension It looks like a candle in it's raw state; very waxy.
Regardless, it'll take less than a minute to spin, and probably about the same time to install. If I don't like it, or don't feel it is safe, it was virtually NO investment on my end
On the flipside, if I DO like it, but still feel a bit sketchy about it, it was STILL no investment, and I'll just get the Zeta hose that deletes it completely
Old 10-02-2012, 04:56 PM   #6
ML
ML's Avatar
Drives: 13 White MT FR-S
Mine is a piece of wood wrapped in electrical tape.
Old 10-03-2012, 08:16 AM   #7
jm1681
Drives: MKVI VW GTI
Alright then XD
Old 10-03-2012, 08:46 AM   #8
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Any aluiminum should be fine. Not all plastics are okay for use in an engine bay. Some thermo plastics have very low melting points, and even lower "glass transition points" where they will become soft and deformable.
Most plastics should be fine but plastic is cheap why risk it. My personal recommendation is Delrin. Great thermal properties, and super easy to machine.
Old 10-03-2012, 09:43 AM   #9
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
I plugged mine with a bolt that fit
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 10-03-2012, 09:47 AM   #10
jm1681
Drives: MKVI VW GTI
Exactly what I was worried about
I BELIEVE that is what we have here The slug we have of it feels a bit waxy, and it FEELS like it would be easily deformable, but we DO make high-speed rollers out of the stuff. It can't be THAT soft, right?
Really, if I find that I'm happy with the delete, I'll just get an intake that deletes it altogether. If anything, this is more of a temporary "see-if-I-like-it" sort of thing
Edit: Oh, BTW Neutron, I'll be using the dimensions you specified in your thread to make my plug
Old 10-03-2012, 10:16 AM   #11
CBR600RR
Drives: Raven Black
Derlin is what they use on motorcycle frame sliders.
I have crashed my bike at the track at 70+ MPH and the frame slider holds up very well to pavement abraision (why it is used)
it is vary heat resistant.
Old 10-03-2012, 10:26 AM   #12
jm1681
Drives: MKVI VW GTI
Sweet ^_^
Hoping to have it made today, and on the car tonight. Oh, any chance anybody knows the size of the opening for the intake resonator beneath the elbow? Might as well eliminate both while we have the lathe setup XD
Old 10-05-2012, 01:26 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have a 3/4 pvc cap glued into a larger 1 inch coupler then painted black. It looks fine, cost under $1, and has lasted with no problems for 7000 miles.
Old 10-05-2012, 02:27 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete GrimmSpeed DIY (Do-It-Yourself) Guides 99 01-25-2015 01:24 AM
Noise Generator Delete for $10.00 xcelir8brz Engine, Exhaust, Transmission 85 11-23-2014 01:39 PM
Noise Generator Delete Plug Dimensions neutron256 DIY (Do-It-Yourself) Guides 26 04-01-2013 12:16 AM
keeping the noise generator with turbo! Silverdub Forced Induction 11 09-27-2012 01:22 AM
Firewall Plug for noise generator Uniquedetail Engine, Exhaust, Transmission 5 09-19-2012 09:16 PM
