Boostin'
Drives: FRS-T
keeping the noise generator with turbo!
wondering if anyone tried it yet, is the whistling inside the car bareable or should i take it out when my setup is finished?
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Boostin'
Drives: FRS-T
so i should just take it off and block the damn hole
Saving them pennies...
The boost pressure will probably blow it right off. Remember there is vac in that system when NA.
#6 | |
Drives: DGM BRZ limited
Try it and let us know what it does. I doubt anyone has tried it so far. However, definitely don't attach it to the intake side unless you are willing to blow the diaphragm out as stated previously.
no there isn't, atleast no major vacuum unless your air filter sucks. There is only significant vac between the engine and throttle body. |
| The Following 2 Users Say Thank You to Cheddar For This Useful Post: | ngabdala (09-19-2012), Sportsguy83 (09-24-2012) |
Boostin'
Drives: FRS-T
I will obviously hook it up between the turbo and the filter lol
form follows function
Drives: RIP '13 BRZ
To quote futurama, as the Planet Express was being dragged down through the depths of the sea and external pressures were building:
"How many atmosphere's can it take!?" "Well, seeing as it's a spaceship, anywhere between zero and one." |
#10 |
if getting turbo
then get real exhuast ditch wimpy sound gen gizmo real throaty exhaust and the car sounds right in and out |
#11 |
Drives: ZC6, Junk of ALL sorts
Yeah. That only blows heat when the engines on a load.
![]() Yes the piping will be replaced anyway. Well you could you the stock piece but .
# 1. Always know where your towel is.
ZC6-CBS, is home |
#12 |
Boosted
Drives: Sideways
Why on earth would you still want the noise generator? If you're boosted your blow off valve + wastegate will be doing the majority of the noise making. Much cooler noises too.
Sent from my Nexus 7
| The Following User Says Thank You to Synack For This Useful Post: | raz0rbladez909 (09-27-2012) |
| Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete | GrimmSpeed | DIY (Do-It-Yourself) Guides | 99 | 01-25-2015 01:24 AM |
| Noise Generator Delete for $10.00 | xcelir8brz | Engine, Exhaust, Transmission | 85 | 11-23-2014 01:39 PM |
| Noise Generator Delete Plug Dimensions | neutron256 | DIY (Do-It-Yourself) Guides | 26 | 04-01-2013 12:16 AM |
| Firewall Plug for noise generator | Uniquedetail | Engine, Exhaust, Transmission | 5 | 09-19-2012 09:16 PM |
| Keeping The Wheel and Shifter clean | LeavingNormal | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 06-23-2012 03:18 AM |
