Old 06-06-2012, 12:32 PM   #1
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Removing and Replacing BRZ/FR-S Intake, Air Filter and Noise Generator Delete
GrimmSpeed DIY Guide Series
Updated 6/6/12
Click this link to download the printable .PDF version of this tutorial
Introduction: This guide will illustrate the basics of the BRZ/FR-S intake system as well as demonstrate removal and easy replacement of air filters. Also included is how to delete the noise generator tube. The difficulty here is relatively low, so take your time and enjoy the job! We know this is something that most of you won't need a guide for, but we figured that as long as we're digging in, we might as well document it and hopefully help some folks out!
Tools: The tools listed below are suggested for this task (figure 1). Optional tools are noted.
- Pliers
- 10mm socket (extension optional)
- Flat head screwdriver
ADDED BY MODERATOR - GOOD TOPIC FOR NOISE GENERATOR DELETE PLUG:
http://www.ft86club.com/forums/showthread.php?t=13696
Tips: Using a 10mm socket instead of a screwdriver on hose clamps can make it much easier to place the hose clamp where you want it for tightening.
Procedure:
1. Begin by collecting your tools and popping your hood. This’ll be quick!
2. (Skip to step 4 for air filter replacement, step 7 for noise generator delete) Start by disconnecting the electrical connector for the MAF (Mass Airflow Sensor) and moving it aside.
3. Remove the wiring harness clip. Use a screwdriver to depress the tabs on both sides of this clip and pull to remove. Move the MAF connector and wiring aside.
4. Use your 10mm socket to loosen the hose clamp connecting the air box to the intake tube and release the two sprung metal clips holding the two halves of the airbox together.
5. Now that the upper airbox is free, you can either pull it aside for filter replacement or remove it for intake removal. If you’re just replacing the air filter, you can simply swap it and re-assemble the intake in the reverse order.
6. Next, we can remove the lower airbox. Simply remove the three (3) 10mm bolts holding it in. The box and resonator should pull right out, set them aside.
7. The only remaining pieces of the intake system are the intake tube and the noise generator. Loosen the hose clamps on the noise generator tube as well as the intake tube and recirculation tube.
8. You’re ready to remove the intake tube. Re-installation is just the reverse of the removal.
9. To remove the noise generator, begin by removing the two (2) 10mm bolts holding it down.
10. Remove the hose routing back to the cabin. Follow the smaller hose from the noise generator to the frame rail below the strut tower. Disconnect the hose from the 90 degree coupler and cap or otherwise cover the open end.
11. The last remaining step in proper removal of the noise generator is to plug the hole that’s left in the intake tube. You can either wait for the release of the GrimmSpeed Noise Generator Delete plug, or visit your local hardware store for a less elegant, but equally functional solution.
Closing:
Remember to plug your MAF sensor back in! As always comments, questions and suggestions are welcomed!
- Matt
GrimmSpeed is offline   Reply With Quote
Old 06-06-2012, 12:44 PM   #2
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
How is the engine db before and after the removal?
Old 06-06-2012, 12:53 PM   #3
GrimmSpeed
GrimmSpeed's Avatar
We'll be on the dyno all afternoon and I've got the dB meter with me, so I'll try and post an in-cabin comparison tomorrow!
- Matt
Old 06-06-2012, 01:27 PM   #4
dsgerbc
Drives: BRZ(sold), STI
May I suggest selling a kit of two plugs: one for the intake tube and another one for the firewall?
dsgerbc is offline   Reply With Quote
Old 06-06-2012, 01:28 PM   #5
GrimmSpeed
GrimmSpeed's Avatar
- Matt
Old 06-06-2012, 01:45 PM   #6
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Why is it necessary to plug the other end of the sound generator tube (The part by the firewall)? Where does it go? Just a one way into some membrane in the dash right?
eikond is offline   Reply With Quote
Old 06-06-2012, 02:26 PM   #7
GrimmSpeed
GrimmSpeed's Avatar
Yep, should be. Also, the sound generator part doesn't seem to actually pass any air, so there's probably no issue at all. On general principle, I just don't like the idea of random garbage collecting in there over time, that's all.
- Matt
Old 06-06-2012, 02:37 PM   #8
Longhorn248
Hook 'em
Longhorn248's Avatar
Looking forward to hearing the dB difference with and without the sound tube. If it's significant I may be interested in a set of plugs for a delete option.
Longhorn248 is offline   Reply With Quote
Old 06-06-2012, 05:29 PM   #9
eikond
eikond's Avatar
- Matt
Yeah, I agree... having open ended pipes in an engine bay is not the best.. you never know what little animal might like to find a home.
Have you traced that pipe through the firewall to see where it ends up.. If i'm going to yank the sound generator.. might as well remove the whole system.
Old 06-06-2012, 08:57 PM   #10
Partial Stall
Drives: '13 WRB BRZ
Great guide! just wish there was a quality intake i could bolt in there :P
Partial Stall is offline   Reply With Quote
Old 06-06-2012, 11:10 PM   #11
GrimmSpeed
GrimmSpeed's Avatar
You'll have options soon enough.
- Matt
Old 06-10-2012, 01:19 PM   #12
Tritty250
Drives: Whiteout FRS
Did it and plugged it with a cap to a liquid jug. Didnt notice a difference in sound or volume. Put it back on till a full cold air comes out. I HATE the location of the MAF sensor on this car? Why not do the proper thing and mount it to the throttle body?
Tritty250 is offline   Reply With Quote
Old 06-11-2012, 08:02 AM   #13
GrimmSpeed
GrimmSpeed's Avatar
Interesting. We did it and measured the dB before and after and found that there was a consistent 3-4dB decrease with the noise generator removed and windows up. That's definitely not an insignificant amount. As far as MAF placement, I suspect that there might be too much turbulence up near the TB for an accurate reading.
- Matt
Old 06-13-2012, 09:21 PM   #14
Tritty250
All hondas have them there, thats where I come from anyways. I would expect the air to be way more turbulent after fighting to get through the filter. But hey, im not an aero engineer so what I say doesnt matter.
Removing interior trim dash panels ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 7 05-30-2012 09:20 AM
Removing the roof antenna denkigrve Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2012 11:59 PM
Replacing Axle's in my Elantra suprachica79 Other Vehicles & General Automotive Discussions 3 10-16-2011 10:25 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
