Old 08-20-2012, 06:45 PM   #15
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by zooki View Post
So I got my springs on yesterday. Took it in for an alignment, and the rear camber is out of spec, but only on the passenger side. -1.5 on the drivers side rear, but -2.1 on the passenger's side. Wondering if it will change with a 200 lb. driver in the car? If not, how much will it hurt to drive until I can get some adjustment for the rear?
It won't be that bad. Unless you do burnouts and stuff all the time. You got a couple thousand miles before the inside wears more often than the outside.
So a 1" drop got you to -2.1? I wonder what the fronts are?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 08-20-2012, 08:41 PM   #16
zooki
Drives: waiting on a 2021...
I can't really say. I put eccentric adjusters in the top strut holes, and just eyeballed them so I could get it to the alignment shop.
zooki is offline   Reply With Quote
Old 08-27-2012, 12:29 PM   #17
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
Mine is similarly aligned (-1.6 and -2.1) in the back after installing the Pro Kit springs. I had purchased the Whiteline Rear Control Arm Upper Inner Bushing kit but haven't installed it, yet. I'm planning on just evening out driver/passenger side, though this probably won't be happening for at least another few weeks. Free time I do not have
Smudgeous is offline   Reply With Quote
Old 08-27-2012, 12:42 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
By itself the fronts will basically be zero still.. it'll change a little but it'll end up .1 or .2 most likely. With Sportlines and whiteline top hats I'm -1.0 on one side and -1.2 on the other IIRC and that -1 comes from the top hats...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-27-2012, 04:31 PM   #19
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'm going for -1.25F/-1.0R
The front is close to what I want
Old 08-30-2012, 09:40 PM   #20
BAE
BAE's Avatar
Drives: BRZ Ltd WRB
What is the best options to adjust camber front and rear? I got the Eibach Pro's today, but will go for coilovers later. The whiteline kits cost $85 for front and $162 for rear.
http://www.whiteline.com.au/do_segue...ehicle=2012-ON
Or could it be smart to go for camber plates from Vorshlag or similar that I also can use with coilovers later?
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
BAE is offline   Reply With Quote
Old 09-17-2012, 11:34 AM   #21
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Install my Eibach Pro-Kit on Saturday and had it alignned this morning, same results as you:
Spec - Right/Left:
Front Camber: -0.2/-0.1
Front Caster: 5.6/5.7
Front Toe: 0.02/0.02
Rear Camber: -1.9/-2.3
Rear Toe: 0.12/0.11
Weird...height is the same on both sides, everything is torqued & installed properly, no binding, no clunks, etc. Camber is just a hair out on the Right Rear...
UPDATE!
Just pulled the alignment spec's from my car's previous alignment (before the Eibach's were installed) due to a steering wheel that was off center;
Rear Camber: -0.9/-1.5
The rear camber was not equal then either, but was still in the "green". Since the Eibach's give in more negative camber, it gave it enough to put it in the "red". My guess is the rear subframe is skewed to the right, looks like I'll need to loosen it up and tweak it to make the camber equal right to left in the rear.
Conclusion: This is not an Eibach issue....
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Improper spring installation warning Memphis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 03-17-2014 12:34 PM
Eibach springs & Black 18x8 with 245/35/18 JMAC75 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-22-2012 10:57 PM
New Eibach Springs for the BRZ/FT86/FR-S RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-19-2012 11:05 AM
Difference in Eibach prokit springs?? leej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-18-2012 08:54 PM
Eibach prokit springs group buy? leej Australia Classifieds 27 06-27-2012 09:47 AM
