Old 07-13-2012, 09:44 PM   #1
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
New Eibach Springs for the BRZ/FT86/FR-S
Just wanted to let everyone know, we just received Eibachs new springs for the BRZ/FT86/FR-S platform and wanted to show some pictures and give some specs. Check it out!!
Whether you're talking about F1, NASCAR, WRC, CART or Indy Car, Eibach regards Motor Sports as the ideal proving ground. The experience they gain at the highest levels of racing is directly converted into the development of the highest-grade chassis components on the planet. And the enthusiasm created by the challenges of motor sports drives them to ever-higher performance-performance that you will enjoy every time you pull out of the pits-or your own garage.
Eibach Pro-Kit Lowering Springs Subaru BRZ 2013 / Scion FR-S 2013
The Eibach Pro-Kit precisely lowers your car's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach Pro-Kit is the finishing touch to a winning recipe for performance. Pro-Kit also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Part #: EIB1 82105.140
Brand: Eibach
Series: Pro-Kit
Return Policy: Standard Return Policy
Mfgr. Warranty: Million Mile
Adjustable: No
Includes Bump Stops: Yes
Drop Height Front: 1.0 in
Drop Height Rear: 1.0 in
Drop Height Front Metric: 25mm
Drop Height Rear Metric: 25mm
Spring Rate Front: 148-200-371 lbs/in (progressive)
Spring Rate Rear: 103-274-388 lbs/in (progressive)
Thanks,
Rick
RallySport Direct is offline
Old 07-13-2012, 09:54 PM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Wow that looks like a well sorted kit. Does anyone have these installed that could give some impressions and share some pics?
industrial is offline
Old 07-13-2012, 09:59 PM   #3
FlipFRS
FlipFRS's Avatar
Drives: Asphalt
DarrenDriven has some. go check the DIY section to look at his build thread
FlipFRS is offline
Old 07-14-2012, 01:25 AM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Thanks @FlipFRS!
Eibach Pro-Kit Review:
http://www.ft86club.com/forums/showthread.php?t=11093
Installing your Eibach Pro-Kit:
http://www.ft86club.com/forums/showthread.php?t=10842
DarrenDriven is offline
Old 07-14-2012, 01:26 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
any word on sportlines?
86_ZN6 is offline
Old 07-14-2012, 01:28 AM   #6
DarrenDriven
NW Region Moderator
I talked with Eibach today, actually. Sportlines are just about ready to ship in bulk. I placed an order for a set so I can install them and review them.
Old 07-19-2012, 10:49 AM   #7
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Rallysport
The Sportline kit (4.10582) is still in production. The second they become available I'll let everyone know. We're hoping within the next couple of weeks...
Jackson is offline
Old 07-19-2012, 10:53 AM   #8
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
Originally Posted by Jackson View Post
Rallysport
the wait.......
Enigmus is offline
Old 07-19-2012, 11:05 AM   #9
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I'm interested to see what the Sportlines will be like. I have had them and the pro kit in the past and loved both... but I don't want to be so low that I scrape the front end on parking lot entries.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 15 07-21-2012 11:46 PM
Difference in Eibach prokit springs?? leej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-18-2012 08:54 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 11:04 AM
Eibach prokit springs group buy? leej Australia Classifieds 27 06-27-2012 09:47 AM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 02:05 PM
