Old 07-05-2012, 11:40 PM   #1
leej
Drives: 86 GTS
Difference in Eibach prokit springs??
Hi
I know the Eibach Pro-Kit springs are the same for the FR-S and BRZ in the US (Same product code) but are they different to the ones for the 86 for JDM, AUS spec or EURO spec cars??
I contacted Eibach australia and I've been told that the prokit springs released in USDM are different to the world market? I smell lies.. does anyone know anything about this??
leej is offline   Reply With Quote
Old 07-06-2012, 01:05 AM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I can have them post in here and tell us. Bump this tomorrow in case I forget.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-06-2012, 01:49 AM   #3
leej
Drives: 86 GTS
thank you, will do
Old 07-06-2012, 10:13 AM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
OK I'll send this over to Tony Jackson now. He's an Eibach employee and is a member here. He'll be able to answer it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-06-2012, 10:48 AM   #5
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Originally Posted by leej View Post
Hi
Typically this is the case. At Eibach North America we do all of our designing and testing around USDM cars and produce the springs here for our market.
Eibach Germany also does their own testing, designing and production for European and Asian market cars. I believe all of the kits for these markets have to be TUV certified so the specs and part numbers will vary between our two markets. In some small cases we do share the same spring application.
I haven't seen any specs from Germany on the GT86 kits yet but I'll shoot them an email to see what their plans are.
Jackson is offline   Reply With Quote
Old 07-06-2012, 07:02 PM   #6
leej
Drives: 86 GTS
Thanks for your info Tony, can you please also find out if the kits are interchangeable, meaning US spec prokits can fit on jdm/aus spec cars and vice versa?
From the forums, I know the 86, FR-S, and BRZ all have diff spring rates and if the BRZ (US spec) and the FR-S (US spec) can use the same US spec prokits, I'm guessing they'll fit the 86 here in Aus or for the fact every spec in the world?
SPRINGS Front/Rate Rear/Rate
OEM Toyota 86 3.0k 3.3k
OEM Scion FR-S 2.3k 3.8k
OEM Subaru BRZ M/T 2.7k 3.5k
OEM Subaru BRZ A/T 2.7k 3.5k
Old 07-07-2012, 09:58 PM   #7
mike2100
mike2100's Avatar
Drives: 23 BRZ
Bit off topic but can you point me to where you got that info? Wanting to know if the source also talks about damping differences and if there are differences between different market 86s/GT86s.
And I had no idea the FR-S front and rear were so unbalanced compared to the 86 - I assumed they were the same. Now I feel like I have a car made for dorifto kids.
Oh well, that can be changed easily.
mike2100 is offline   Reply With Quote
Old 07-07-2012, 10:12 PM   #8
Dimman
Kuruma Otaku
Dimman's Avatar
People need to understand that the motion ratio (leverage) of the rear suspension basically 'softens' the rear rate.
It is not unbalanced.
Because titanium.
Old 07-07-2012, 10:16 PM   #9
mike2100
mike2100's Avatar
Drives: 23 BRZ
But the FR-S front:rear ratio is quite different from the 86. So assuming one of them is balanced, the other is unbalanced... or should we say "less balanced."
Old 07-08-2012, 02:24 AM   #10
leej
Drives: 86 GTS
its in the BRZ/FR-S Suspension Options List (Springs and Coilovers) sticky
Old 07-09-2012, 10:50 AM   #11
Jackson
Jackson's Avatar
We'll know sooner or later but this information has to be passed down from the other Eibach groups once fitment is confirmed. ie; Eibach Germany, Eibach Austrailia, Eibach Japan, etc. I'll post up once I know for sure.
Old 07-15-2012, 08:17 PM   #12
Eibach Australia
Drives: Toyota 86
Hi all,
Below is our reply to LeeJ who unkindly accused Eibach Australia of lying.
Li,
You’re obviously referring to shop sites in the US, those kits have been developed by Eibach in the US tuned for their local market.
Eibach Germany is developing a range to suite the worldwide market which is far better suited to Australia, this range may also include the Bilstein Dampers all made in Germany.
Kind Regards,
Eibach Australia
As you can see from our email to LeeJ and the reply in this thread from Tony Jackson at Eibach USA, that we did not in fact lie to LeeJ.
We at Eibach Australia take the up most care and consideration to give the best advice to our customers, especially when it comes to new applications coming into the market.
At this stage we are aware that there are 3 versions of the 86 on the market around the world - US, Japanese and Australia. We are currently in the research stage of finding out what application - US or German will be best suited to the Australian version vehicle.
If you have any further enquiries please contact us at Eibach Australia.
Eibach Australia is offline   Reply With Quote
Old 07-18-2012, 08:09 PM   #13
Z86
Drives: 86 GTS Auto in Pegasus White
Originally Posted by Eibach Australia View Post
Hi all,
Hey Eibach Australia, can you see any issues with the US kit on Australian cars?
Z86 is offline   Reply With Quote
Old 07-18-2012, 08:54 PM   #14
Eibach Australia
Drives: Toyota 86
At this stage the development of the of the German produced Pro Kit to suite the Toyota 86 is incomplete, this kit will be released soon. There may be a significant difference between the US and German Kits, as we have experienced this on a lot of other models and makes. We understand that the 86 built in Japan for Australia is different to the North America delivered vehicles, we are therefore waiting till the data is available to compare.
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 15 07-21-2012 11:46 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 11:04 AM
Eibach prokit springs group buy? leej Australia Classifieds 27 06-27-2012 09:47 AM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 02:05 PM
