Old 08-14-2012, 08:50 PM   #1
zooki
Drives: waiting on a 2021...
alignment with Eibach springs?
Anybody have a problem with alignment after installing the Eibach Pro-line springs? I have ordered adjustable strut bolts for the front, but was wondering about the rear. Any problems, or can the stock adjustments handle te springs? Thanks.
zooki is offline   Reply With Quote
Old 08-14-2012, 09:03 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Depends on what you want for rear camber. If you have too much rear camber you can pull some out with the whiteline adjusters for fairly cheap.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-14-2012, 09:45 PM   #3
zooki
Probably just aligned back to stock specs. This is my daily driver, don't need anything too aggressive.
Old 08-14-2012, 10:08 PM   #4
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
According to: http://www.ft86club.com/forums/showt...382#post296382
Originally Posted by Evasive Motorsports View Post
EIBACH PRO-KIT SCION FR-S & SUBARU BRZ
TECHNICAL INFORMATION
FRONT:
FR-S OE rate: 23 N/mm (131 lbs/in)
BRZ OE rate: 27 N/mm (153 lbs/in)
PK rate: 26-35-65 N/mm (148-200-371 lbs/in)
Tubing: No
Bump-stop: New Eibach bump-stop
Damper: OE
OE wheel center to fender: 370 mm (14.6 in)
PK wheel center to fender: 345 mm (13.6 in)
Front Alignment:
OE Camber = 0.00 deg (+/-0.75 deg)
OE Caster = 5.9 deg (+/-0.00 deg)
OE Total Toe = 0.0 deg (+/-0.18 deg)
PK Camber = -0.2 deg
PK Caster = 5.9 deg
PK Toe = 0.0 deg
Approximate installation time: 1.0 hr
REAR:
FR-S OE rate: 37 N/mm (211lbs/in)
BRZ OE rate: 34 N/mm (195 lbs/in)
PK rate: 18-48-68 N/mm (103-274-388 lbs/in)
Tubing: Yes
Damper: OE
Rear Alignment:
OE Camber = -1.25 +/-0.75 deg.
OE Total Toe = 0.12 deg. +/-0.18 deg
PK Camber = -1.7 deg.
PK Total Toe = 0.12 deg
PRO-KIT can be aligned to OE specifications.
Old 08-15-2012, 07:07 PM   #5
Jackson
Jackson's Avatar
Drives: E46 M3 (daily) / EG Civic (track)
Eibach is currently designing adjustable rear arms to adjust camber and toe for the FR-S and BRZ. They will be needed to dial in preferred alignment specs if you modify your ride with springs or coilovers.
Jackson is offline   Reply With Quote
Old 08-15-2012, 09:19 PM   #6
zooki
When can we expect these, and how much?
Old 08-16-2012, 11:14 AM   #7
Jackson
Jackson's Avatar
They are still in the design phase but all of the parts we're developing for these cars are high priority. I'm hoping we'll have pieces in the next month or two. I'm sure updates will be posted by myself or others as we have more info and photos to share.
Old 08-16-2012, 02:16 PM   #8
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I don't see how they can claim that the car can be aligned back to stock specs without aftermarket camber adjusters. The car has no camber adjustment stock.
Bit skeptical.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 08-16-2012, 02:26 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Bit skeptical.
OE Spec is 1.25 +/- .75, or .5-2.00. They measured 1.7, which is in the OE range.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-19-2012, 02:28 PM   #10
Synack
Boosted
Synack's Avatar
Drives: Sideways
Wait wait wait. If I am reading this correctly, stock front camber is ZERO and rear is -1.25????
That seems stupid to me. You'd figure it would be front camber around -0.5 to -0.75 and the rear around -0.25 to -0.5.
Personally I'll be running about -1.25 up front and -1 in the rear; for drifting.
Old 08-19-2012, 03:44 PM   #11
ultra
Curious cat.
ultra's Avatar
Whiteline said pretty much that in their video analysis of the OEM suspension.
IIRC they saw around 0 degrees of camber up front and -1.1 or so in the rear, with slight toe out front and a little toe in out back.
http://www.ft86club.com/forums/showthread.php?t=11210
What I'm curious about what Eibach means when they claim that the alignment can be *adjuated* to factory specs when it's pretty widely known that the car doesn't have any camber adjustment from the factory.
Saying that the alignment 'happens to fall within OEM tolerances' with the springs installed would have been clearer than saying tha it cam be adjusted.
Unless they're referring to toe only.
Old 08-19-2012, 06:29 PM   #12
Synack
Boosted
Synack's Avatar
Drives: Sideways
Gotcha. Well looks like I'll only need a rear camber adjustment after getting a drop. A 1-1.4 inch drop should put me around -1.25 up front hopefully. WAY too much camber in the back though.
Old 08-20-2012, 06:15 PM   #13
zooki
So I got my springs on yesterday. Took it in for an alignment, and the rear camber is out of spec, but only on the passenger side. -1.5 on the drivers side rear, but -2.1 on the passenger's side. Wondering if it will change with a 200 lb. driver in the car? If not, how much will it hurt to drive until I can get some adjustment for the rear?
Old 08-20-2012, 06:42 PM   #14
empower-auto
Kouki-Monster
empower-auto's Avatar
Considering it will be upper arms .. it will be $$$.
Battle Version will have some stuff out for this car soon I bet.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Improper spring installation warning Memphis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 03-17-2014 12:34 PM
Eibach springs & Black 18x8 with 245/35/18 JMAC75 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-22-2012 10:57 PM
New Eibach Springs for the BRZ/FT86/FR-S RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-19-2012 11:05 AM
Difference in Eibach prokit springs?? leej Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-18-2012 08:54 PM
Eibach prokit springs group buy? leej Australia Classifieds 27 06-27-2012 09:47 AM
