BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
09-14-2022, 11:12 AM | #1 |
Drives: 2022 BRZ 6MT
Crash bolt installation question
I've seen and read a number of tutorials on installing crash bolts for the 1st gen twins but I haven't been able to find as detailed information on the 2nd gen. Can anyone with access to the service manual confirm whether the torque spec is the same as on the gen 1 (114 lb-ft according to
)? I assume the installation process is identical otherwise. On a more subjective note… is it worth the trouble? |
09-15-2022, 04:16 AM | #2 |
Drives: zd8 brz
torque spec is the same. install is the same
it's a very easy install and only really takes a few minutes once the car is in the air. for the $20-$30 spent, it's likely the best thing you can do to get more responsive turn-in feel from the car |
The Following User Says Thank You to mycrors7 For This Useful Post: | ZionsWrath (09-10-2023) |
09-15-2022, 09:47 AM | #3 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Hope this isn't too OT, but does the installation of the crash bolts allow you to adjust the camber to suit your needs, or does it lock you into a specific amount of camber?
I seem to remember reading on my old car, your camber choices were 0 with stock equipment and around -3 degrees with the crash bolts. While I wouldn't mind being able to dial in a bit more camber, I don't want to go to aggressive either would like the ability to chose my own "poison". |
09-15-2022, 10:41 AM | #4 |
Drives: what
not sure you'd get all the way to -3 with them. you might need offset or adjustable tophats (camber plates) to get all the way to -3.
09-15-2022, 01:25 PM | #5 | |
Drives: Some kind of Subaru
If you push the strut all the way in, you basically go from 0 degrees to -1 (maybe -1.4ish at most) with the stock struts. The crash bolts aren't eccentric bolts. |
The Following User Says Thank You to G_Ride For This Useful Post: | Racecomp Engineering (09-15-2022) |
09-15-2022, 02:58 PM | #6 |
Drives: what
my bad. could have sworn i used some in the past that were eccentric but they weren't on a subaru
09-15-2022, 07:03 PM | #7 |
09-15-2022, 07:03 PM | #8 |
09-16-2022, 08:28 AM | #9 | |
Spelling Impaired
I'm not after any crazy camber settings, but a bit more to improve turn in would be nice. Good to know there is a even a little adjustability in the stock suspension. |
10-18-2022, 10:44 PM | #10 |
Drives: 22 gr86
This video is hilarious
09-08-2023, 11:34 AM | #11 |
Spelling Impaired
Hopefully this isn't a dumb question, but I haven't seen it mentioned in any of the threads I read on this topic.
Does the correct nut come with the crash bolt as a set, or do you order them separately? From the diagram on parts.subaru.com, it looks like the nut for the 14mm bolt is part number N380008. I'll be getting an alignment done soon and figured I'd knock out this mod while I was at it. I'd hate to get the appointment made and the bolts ordered, only to find out they don't come with the nuts and have to put everything on hold until I got them in. Thanks all! |
09-08-2023, 11:51 AM | #12 | |
Drives: 22 BRZ limited
The Following User Says Thank You to dragoontwo For This Useful Post: | Desertnate (09-08-2023) |
09-08-2023, 03:43 PM | #13 |
Drives: '22 BRZ
The nuts are totally reusable from the prior bolt. The threads are the same.
The Following User Says Thank You to DocWalt For This Useful Post: | Desertnate (09-11-2023) |
09-08-2023, 03:54 PM | #14 |
Drives: 2018 BRZ
Just noting that the nuts are actually not supposed to be reused - they are marked as a non-reusable part in the service manual. Many people (myself included) will reuse these sorts of hardware, though.
Similar Threads | ||||
camber bolt installation question. | msaikhan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-20-2019 09:19 PM |
Crash bolt install question | cab33 | DIY (Do-It-Yourself) Guides | 2 | 07-09-2015 03:19 AM |
Crash bolt installation question | slowbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-01-2013 12:37 AM |
Crash bolt question | ayau | Tracking / Autocross / HPDE / Drifting | 8 | 08-17-2012 01:22 PM |
BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
