| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Fast
Crash bolt install question
The Toyota part number for the crash bolt I got off this forum is SU003-02818.
In the parts diagram it calls it "Strut lower bolt" In this video they show replacing the upper bolt Can someone help me with the confusion? |
The normal upper strut bolt has a larger diameter than lower bolt.
To adjust the camber you use the lower/crash bolt (same part, two names) in the upper hole and since it is smaller diameter you get the camber adjustment. |
| The Following User Says Thank You to jvincent For This Useful Post: | cab33 (07-07-2015) |
BAE
Drives: Asphalt FRS
Or you can buy a 16mm camber bolt and replace the top bolt like the video did.
Smaller bolt up top will yield some camber. Camber bolt in upper strut hole will yield more camber. |
| Vortech Install question... where does this hex bolt go??? | sissupr | Forced Induction | 9 | 06-20-2014 05:25 PM |
| Just installed crash bolt. | normanb21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 05-21-2013 04:27 PM |
| Crash bolt installation question | slowbrz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-01-2013 12:37 AM |
| Crash bolt question | ayau | Tracking / Autocross / HPDE / Drifting | 8 | 08-17-2012 01:22 PM |
| BRZ crash bolt same as Impreza lower strut bolt? | xwd | Tracking / Autocross / HPDE / Drifting | 0 | 07-05-2012 12:19 PM |
