Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-14-2022, 12:12 PM   #1
br33z
Drives: 2022 BRZ 6MT
Crash bolt installation question
I've seen and read a number of tutorials on installing crash bolts for the 1st gen twins but I haven't been able to find as detailed information on the 2nd gen. Can anyone with access to the service manual confirm whether the torque spec is the same as on the gen 1 (114 lb-ft according to
)? I assume the installation process is identical otherwise.
On a more subjective note… is it worth the trouble?
br33z is offline   Reply With Quote
Old 09-15-2022, 05:16 AM   #2
mycrors7
mycrors7's Avatar
Drives: zd8 brz
torque spec is the same. install is the same
it's a very easy install and only really takes a few minutes once the car is in the air.
for the $20-$30 spent, it's likely the best thing you can do to get more responsive turn-in feel from the car
mycrors7 is offline   Reply With Quote
The Following User Says Thank You to mycrors7 For This Useful Post:
ZionsWrath (09-10-2023)
Old 09-15-2022, 10:47 AM   #3
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Hope this isn't too OT, but does the installation of the crash bolts allow you to adjust the camber to suit your needs, or does it lock you into a specific amount of camber?
I seem to remember reading on my old car, your camber choices were 0 with stock equipment and around -3 degrees with the crash bolts. While I wouldn't mind being able to dial in a bit more camber, I don't want to go to aggressive either would like the ability to chose my own "poison".
Desertnate is offline   Reply With Quote
Old 09-15-2022, 11:41 AM   #4
MyHybridBurnsGasAndTires
Drives: what
not sure you'd get all the way to -3 with them. you might need offset or adjustable tophats (camber plates) to get all the way to -3.
MyHybridBurnsGasAndTires is offline   Reply With Quote
Old 09-15-2022, 02:25 PM   #5
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
It allows you to adjust camber within a very narrow range. The crash bolt is is just a smaller diameter bolt.
If you push the strut all the way in, you basically go from 0 degrees to -1 (maybe -1.4ish at most) with the stock struts.
Originally Posted by MyHybridBurnsGasAndTires View Post
they are eccentric bolts...they have a lobe on them to allow you to adjust the camber (to some degree).
The crash bolts aren't eccentric bolts.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
Racecomp Engineering (09-15-2022)
Old 09-15-2022, 03:58 PM   #6
Drives: what
my bad. could have sworn i used some in the past that were eccentric but they weren't on a subaru
Old 09-15-2022, 08:03 PM   #7
br33z
Thank you!!
Old 09-15-2022, 08:03 PM   #8
G_Ride
G_Ride's Avatar
Some cars do come with eccentric bolts from factory. Being an owner of a GD Impreza years ago, I know that car had eccentric bolts from factory.
Old 09-16-2022, 09:28 AM   #9
Desertnate
Spelling Impaired
Perfect. That was what I wanted to know.
I'm not after any crazy camber settings, but a bit more to improve turn in would be nice. Good to know there is a even a little adjustability in the stock suspension.
Old 10-18-2022, 11:44 PM   #10
loungin
Drives: 22 gr86
This video is hilarious
loungin is offline   Reply With Quote
Old 09-08-2023, 12:34 PM   #11
Desertnate
Spelling Impaired
Hopefully this isn't a dumb question, but I haven't seen it mentioned in any of the threads I read on this topic.
Does the correct nut come with the crash bolt as a set, or do you order them separately? From the diagram on parts.subaru.com, it looks like the nut for the 14mm bolt is part number N380008.
I'll be getting an alignment done soon and figured I'd knock out this mod while I was at it. I'd hate to get the appointment made and the bolts ordered, only to find out they don't come with the nuts and have to put everything on hold until I got them in.
Thanks all!
Old 09-08-2023, 12:51 PM   #12
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Thanks all!
You have to order the nut separately.
The Following User Says Thank You to dragoontwo For This Useful Post:
Desertnate (09-08-2023)
Old 09-08-2023, 04:43 PM   #13
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The nuts are totally reusable from the prior bolt. The threads are the same.
The Following User Says Thank You to DocWalt For This Useful Post:
Desertnate (09-11-2023)
Old 09-08-2023, 04:54 PM   #14
Ohio Enthusiast
Drives: 2018 BRZ
Just noting that the nuts are actually not supposed to be reused - they are marked as a non-reusable part in the service manual. Many people (myself included) will reuse these sorts of hardware, though.
camber bolt installation question. msaikhan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-20-2019 10:19 PM
Crash bolt install question cab33 DIY (Do-It-Yourself) Guides 2 07-09-2015 04:19 AM
Crash bolt installation question slowbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-01-2013 01:37 AM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 02:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
