Old 01-21-2022, 09:44 AM   #127
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by DocWalt View Post
Would also be nice to go bolt to bolt on the subframe too
I'm not sure that they changed the subframe mount points, but just extended the rear suspension bits by 10mm.
I made a mistake in my previous statement. let me go back and fix it.
The Following User Says Thank You to dragoontwo For This Useful Post:
DocWalt (01-21-2022)
Old 01-21-2022, 10:03 AM   #128
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I thought the changes were at the knuckle side according to CSG Mike?
Old 01-21-2022, 10:16 AM   #129
dragoontwo
dragoontwo's Avatar
I must have missed that post. A quick glance at the parts page shows the RLCA and knuckle being the parts specific to the 2022. I suppose my idea was wrong. However with the only change in the RLCA being that the hole moved outboard 10mm, my shock is now where it would have been on the previous model.
After some digging, I found this post by MikeCSG that states the rear measurements are identical with the change being in the rear quarter panel. In a post on the next page, he attributes the track width increase to the wheel width increase. So it looks like my theory was totally wrong.
Old 01-21-2022, 01:44 PM   #130
Racecomp Engineering
Originally Posted by dragoontwo View Post
Like a flip chip for mountain bike geometry...
The Cusco rear arms have a flippable thing that changes the motion ratio.
The arms still use a pillowball so not legal but just showing what it looks like.
- Andrew
CSG Mike (01-21-2022), timurrrr (01-21-2022)
Old 01-21-2022, 02:30 PM   #131
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
But the '17–20 PP wheels were also 7.5" wide, and neither of those brochures call out a different track with for PP models.
I thought track width is measured from the center of the tire tread to the center of another tire tread, so it shouldn't change with wheel/tire width, assuming the same wheel offset?
Then also why 10 mm, not 12 or 13?
dimensionally identical, when it comes to track width
That being said, I have no idea how track width is measured by manufacturers, down to the millimeter.
Could be more what you'd call a "guideline" ballpark number than an actual precise measurement.
Old 01-21-2022, 02:59 PM   #132
bholliday
Drives: 2022 BRZ Premium
I'm guessing the track width for the brochure is probably measured in the CAD models. You certainly can get a nominal measurement that is way more precise than 1 mm.
bholliday is offline   Reply With Quote
The Following User Says Thank You to bholliday For This Useful Post:
Yoshoobaroo (01-21-2022)
Old 01-24-2022, 05:39 PM   #133
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Being the wheels are 7.5 wide all around, why don't they claim the front track being wider?
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 01-24-2022, 07:10 PM   #134
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I assumed they measure based on the wheel hub as there was no track width change on the special edition cars with 7.5’s iirc.
The wheel isn’t centered on its mating surface to the car so wider wheels do not necessarily result in no change to track width as measuring wheel center to wheel center.
ineedyourdiddly
Old 01-26-2022, 12:49 PM   #135
Brock H.
Drives: 2022 BRZ, Red
Stupid question time.
Double checked the rules, but I figured I'd ask to double check. As Subaru has no "Manufacturer" camber bolts for the BRZ as defined in 13.8.E, aftermarket camber bolts are also a no, correct? How does one realistically get any front camber on these besides loosening everything and using the hole tolerances to get camber?
Brock H. is offline   Reply With Quote
Old 01-26-2022, 01:00 PM   #136
dragoontwo
dragoontwo's Avatar
Factory "crash" bolts. Basically the lower 14mm bolts placed into the top 16mm holes. They're pretty cheap at the dealer.
I'm not sure if these are legal though.
Old 01-26-2022, 01:07 PM   #137
Brock H.
That was my guess at the moment.
Old 01-26-2022, 03:12 PM   #138
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
They're legal. same part number as the 1st gen cars. Its in the service manual.
MacSpeed is offline   Reply With Quote
The Following 5 Users Say Thank You to MacSpeed For This Useful Post:
Brock H. (01-26-2022), DocWalt (01-26-2022), dragoontwo (01-26-2022), otter (01-26-2022), timurrrr (01-26-2022)
Old 02-08-2022, 10:29 AM   #139
MMoore4545
Drives: 2022 BRZ
Has anyone gotten a letter written to STAC regarding the RCLA's?
'91 Fc3s Turbo
'22 Brz Limited MT
Too Many motorcycles.
MMoore4545 is offline   Reply With Quote
The Following User Says Thank You to MMoore4545 For This Useful Post:
timurrrr (02-08-2022)
Old 02-08-2022, 10:32 AM   #140
Banannie
Drives: 2022 BRZ, 2008 S2K CR Delete
And ask for what? I'm not asking to be controversial, just truly curious - the STAC won't make allowances for a single car
Banannie is offline   Reply With Quote
SCCA AutoX Classing... Roadcone Tracking / Autocross / HPDE / Drifting 13 10-21-2014 05:02 PM
Carbon fiber hood & SCCA classing TimR Tracking / Autocross / HPDE / Drifting 21 06-17-2014 12:27 PM
AutoX and classing chappys4life Tracking / Autocross / HPDE / Drifting 16 02-20-2013 03:38 PM
Autocross next wknd for me! Interesting response re: classing.. MarkRacerX Tracking / Autocross / HPDE / Drifting 42 06-18-2012 01:52 AM
