Old 01-19-2022, 04:59 PM   #113
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by dragoontwo View Post
I get ~94 for the first, and ~189 for the second.
That was quick, thanks!
Based on your profile info, that arm is from a 2022 BRZ — is that right?
So they moved the strut hole closer to the knuckle, interesting. I thought it was the opposite.
I noticed you measured the distance between two edges of the holes.
Did you measure the diameter of the holes too? I'm not 100% sure if they are the same on a stock arm or not. On the Verus arm, the three holes were of at least two different sizes, so I tried to measure center to center.
On your second picture, I see ~209.5 mm. I presume you put the 20mm mark in the middle of the first hole? Perhaps you've forgotten to include a third picture?
Old 01-19-2022, 05:37 PM   #114
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I misspoke, it’s not a ball joint it’s a set of eccentric bushings in the a arm like a Miata.
https://www.whiteline.com.au/product..._number=KCA326
You could also do an aftermarket upper control arm like this one;
https://racerxfabrication.com/frs-br...r-control-arms
Given that the rear falls naturally close to them desired camber the whiteline kit should be plenty, if it is a pain in the ass to adjust.
Thank you so much. I'll bookmark em and keep this post in mind.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 01-19-2022, 05:51 PM   #115
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by timurrrr View Post
Can someone measure precisely (±1 mm) the distance between holes on gen.2 stock RLCAs?
My measurements of the Verus RLCAs:
Knuckle bolt/Strut bolt 104mm
Knuckle bolt/ARB end link bolt 189mm
Someone who already has a GR86 just messaged me saying it's also ~94/~189 on his car.
The Following User Says Thank You to timurrrr For This Useful Post:
DocWalt (01-19-2022)
Old 01-19-2022, 06:23 PM   #116
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Yes, mine is a 22. It shouldn't matter what size the bolt holes are because I measured from outboard to outboard edge. Though I do believe they are the same size. Yes I had the 20mm lined up in the knuckle hole. It's not a great measurement because there's a slight bulge in the stock arm.
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
DocWalt (01-19-2022), timurrrr (01-19-2022)
Old 01-20-2022, 02:31 PM   #117
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
According to parts.subaru.com, 2022 Subaru BRZ uses 20250AL011, which was also used on 2015-2017 WRX and STI.
So perhaps we can just use whatever adjustable RLCAs were ST-legal on those cars?
Does anyone know of any?
DocWalt (01-20-2022)
Old 01-20-2022, 03:26 PM   #118
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I emailed Verus and if I understood them correctly they sell the exact same arm to WRX and BRZ buyers.
Now you know what to do if a 2015-2017 WRX or STI beats you
Old 01-20-2022, 03:50 PM   #119
RRslip
Drives: Black BRZ - STX
I my opinion, it would go a long way for this community to reject this as a something that matters. If everyone does it, would a protest really happen? Will a PC really throw everyone out for making their motion ratios worse? I sure hope not.
Todd K. | Ohio | STX 16' BRZ | 330F/500R | Perrin 22mm front, Karcepts rear
RRslip is offline   Reply With Quote
The Following 3 Users Say Thank You to RRslip For This Useful Post:
DocWalt (01-20-2022), Kelse92 (01-20-2022), strat61caster (01-20-2022)
Old 01-20-2022, 04:07 PM   #120
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Aftermarket parts are rarely going to follow the exactly letter of our rules… they have much bigger fish to fry than the ones in the tiny pool of autocrossers. I get following to the letter of the rules and all. But this is an incidental change with what’s available on the current market. Reminds me a lot of the bushing metal content discussion from last year..
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
The Following User Says Thank You to Kelse92 For This Useful Post:
Old 01-20-2022, 04:11 PM   #121
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Kelse92 View Post
Drilling a hole is simple enough but I dunno, trying to make things simple
Drilling a 10/12 mm hole 10 mm away from an existing 10/12 mm hole without affecting the structural rigidity of a suspension arm doesn't sound very easy to me.
Old 01-20-2022, 05:07 PM   #122
cjd
cjd's Avatar
Drives: 2017 BRZ
update to an insert which can be flipped for gen1 vs gen2? Dunno. Silly but what can we do...
Old 01-20-2022, 05:20 PM   #123
dragoontwo
dragoontwo's Avatar
Like a flip chip for mountain bike geometry...
The Following User Says Thank You to dragoontwo For This Useful Post:
DocWalt (01-21-2022)
Old 01-20-2022, 05:29 PM   #124
cjd
cjd's Avatar
Drives: 2017 BRZ
"koni insert" is precedent? But some coilovers for the platform do this up front (the Tein SRC I had did). "Easy" to retrofit, simple part to make...
Old 01-21-2022, 08:59 AM   #125
dragoontwo
dragoontwo's Avatar
To muddy this RLCA talk a bit, lets also add in the fact that I believe they pushed the subframe out by 5mm per side(remember they widened the rear track 10mm). By also moving the shock hole outboard 10mm on the RLCA they moved it by a total of 15mm compared to first gen(assuming no changes on top mount). By using SPC RLCA moving the hole 10mm inboard gets closer to first gen shock geometry.
Can we get somebody with a first gen to measure bolt to bolt on the rear shock top mount in the trunk? I can do mine when I get home.
Old 01-21-2022, 09:30 AM   #126
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Would also be nice to go bolt to bolt on the subframe too
SCCA AutoX Classing... Roadcone Tracking / Autocross / HPDE / Drifting 13 10-21-2014 05:02 PM
Carbon fiber hood & SCCA classing TimR Tracking / Autocross / HPDE / Drifting 21 06-17-2014 12:27 PM
AutoX and classing chappys4life Tracking / Autocross / HPDE / Drifting 16 02-20-2013 03:38 PM
Autocross next wknd for me! Interesting response re: classing.. MarkRacerX Tracking / Autocross / HPDE / Drifting 42 06-18-2012 01:52 AM
