Old 01-02-2021, 02:36 PM   #15
norcalpb
norcalpb's Avatar
It could also be for ease of removal with an exhaust that runs down the center-line of said sway bar. I have a Perrin exhaust and getting the rear sway bar “hooks” around the mounting brackets can be a real PITA sometimes. You get one hook on and the other hook just barely can’t fit around it’s bracket. You try to the raise both hooks at the same time but the exhaust gets in the way forcing you to only raise one side of the bar at a time.
Center GRMN exhaust:
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
JIM THEO (01-02-2021), PulsarBeeerz (01-03-2021)
Old 01-03-2021, 03:36 AM   #16
gpvecchi
gpvecchi's Avatar
I don't think it's center exhaust related either, the GR model has center exhaust but standard bar.
Definetely I'd not say it's obstruction related.
Old 01-03-2021, 12:05 PM   #17
norcalpb
norcalpb's Avatar
Can you post a picture of the "GRMN" rear end? I've always thought the 2016 GR was the only GR car made.
Old 01-03-2021, 09:52 PM   #18
Turdinator
Señor Member
Turdinator's Avatar
I just discovered that the 86 GRMN uses a 15 mm rear ARB like facelifted models, but with different shape.
Is there some expert that can explain what would change?
Are you sure that isn't a pic of a front sway bar used by accident?
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
gpvecchi (01-04-2021), NoHaveMSG (01-03-2021)
Old 01-04-2021, 01:01 AM   #19
gpvecchi
gpvecchi's Avatar
If you Google "86 GRMN" you'll find a lot of pictures...
https://toyotagazooracing.com/pages/grmn/86/sp/#concept
No, the photo is correct, the part number is specific to GRMN...
Old 01-04-2021, 04:46 AM   #20
JIM THEO
Drives: BRZ 2018
The two curves in the middle of the long straight part of the yellow OEM bar gives increased torsional rigidity compared with a same diameter straight bar.
Besides the GR one was introduced before the >MY17 thicker OEM bar so probably it's designed and produced by Toyota, not Subaru.
By the way the exhaust manifold of the GRMN car compared with the upgraded CS-R3 race car manifold (afaik produced by Rogue Motorsport quite similar with ACE350) is quite different design:
https://racing.tgr-europe.com/wp-con...ge_2017_02.pdf (page 6)
GRMN:
JIM THEO is offline   Reply With Quote
The Following User Says Thank You to JIM THEO For This Useful Post:
Thefalls (01-04-2021)
Old 01-04-2021, 11:52 AM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In all the formulas I have seen to calculate torsion bar stiffness , none of them have accounted for the geometry within the length of the torsional section.
Old 01-04-2021, 08:35 PM   #22
Turdinator
Señor Member
Turdinator's Avatar
If it is to suit the rally car it may well be designed to allow greater suspension articulation.
1974 TA22 Celica
2013 86 GT
SCFD (01-08-2021), Spuds (01-08-2021)
Old 01-08-2021, 02:02 AM   #23
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Bends basically vary the moment of inertia along the length. It does make a difference in stiffness, but it's a PITA to calculate without a full solid model and even then you might be better off just making and testing it if you really wanted to know.
Anyway, I don't know why the bends are more pronounced on one vs the other except if they wanted to give greater clearance to something either for heat dissipation or physical interference issues. Maybe one is easier to manufacture? Maybe they were actually less concerned with something like ground clearance or something on the GR vs the TRD.
The Following User Says Thank You to Spuds For This Useful Post:
NoHaveMSG (01-08-2021)
Old 01-08-2021, 02:03 AM   #24
Spuds
The Dictater
Spuds's Avatar
Now there is some merit in that idea. Or different articulation such as lowered or raised
Old 01-08-2021, 04:40 AM   #25
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
That is, as you say, different articulation
Old 01-08-2021, 08:27 AM   #26
Spuds
The Dictater
Spuds's Avatar
I was assuming that greater articulation meant a longer arc specifically, where I was adding that instead of longer travel, it may be the same amount shifted up or down.
SCFD (01-08-2021)
Old 10-17-2021, 01:23 AM   #27
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It looks that they wanted to go into a much softer sway bar, one that was softer even from the old 14 mm bar. In general the GRMN 86 had a chassis that was 1.8 times stiffer than the base model offered at that time, so in such case you can go into much softer suspension settings and gain in overall mechanical grip.
Another thing to point out is that a few ideas that were tested in the GRMN car have passed to the new GR86 car. Sad thing is that they couldn't pass the revised FA20 engine with the output of 219 PS (19 PS more) at 7,300 rpm and 217 Nm (12 Nm more) at 5,200 rpm. Problem was that Subaru couldn't make such a well balanced engine and they didn't want to revise their engine production process. So for Subaru the easier route was just to increase the engine displacement, although the rest of the world was downsizing their engines.
Old 10-17-2021, 01:49 AM   #28
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Looks like a front bar to me. People upload the wrong picture to the part sites all the time.
Edit: actually the bends don't match up at all, I doubt that bar is even for an 86. Critical mount points aren't changed willy nilly on production cars.
ineedyourdiddly
Springs shape gpvecchi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 11-05-2020 07:32 PM
{NY} BRZ SPC LCA's used 3KMI in great shape $OLD BRZ!@# Brakes, Suspension, Chassis 1 06-26-2018 07:01 PM
Fender vent shape Gunman Cosmetic Modification (Interior/Exterior/Lighting) 4 05-04-2016 04:29 PM
Headlight shape cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 5 02-28-2013 04:44 AM
