ARB shape
Rust bucket enthusiast
The bar may have the shape to give access to the bolts on the rear diff mount
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Drives: Subaru BRZ
Cost cutting, less kinks = less material.
I wonder if having the "bend" closer to the bushings causes the bar to have a lower spring rate? Maybe more? Good find though.
I'm curious to see if the rear endlinks are different because look at the intense angles of the bar ends compared to stock. Makes me almost think theres like a 1" GR endlink or something. |
| The Following User Says Thank You to norcalpb For This Useful Post: | gpvecchi (01-02-2021) |
This is interesting as I can't think of another example where different ARB geometries are used on the same vehicle.
I'm not sure why they would change the geometry but the change may result in a different spring rate. |
| The Following User Says Thank You to SCFD For This Useful Post: | gpvecchi (01-02-2021) |
To clarify, the GRMN is the black one, the yellow is a JDM TRD, same shape of the OEM.
Endlinks are different, too. It's my opinion that the spring rate changes, too, but I think there is something else, or a different diameter will be sufficient. My two cents: shorter lever, stiffer spring. |
Drives: Toyota 86
Maybe some clearance issues with a different differential or bracing? Always good find from you though
Drives: 2014 Ultramarine FR-S
Might be for clearance around what appears to be a subframe brace:
Drives: 2014 GT86
Somehow exhaust headers in this pic reminded me of facehuggers from "Alien"
| The Following 5 Users Say Thank You to churchx For This Useful Post: | Ernest72 (01-03-2021), gpvecchi (01-02-2021), JD001 (10-17-2021), SCFD (01-03-2021), x808drifter (01-02-2021) |
#10 |
Nope, I have all the GRMN bracing, no interference.
Differential has the same housing, just 4.3 ratio and different TBR. |
#11 | |
Drives: Crapcan
#12 |
Drives: 2014 GT86
But if bar is longer due extra bends, even of same material & thickness it should be easier to bend, no? Though in this case clearance of bracing sounds right reasoning.
#13 | |
Drives: Crapcan
ARB shape
Correct, but if the goal is to make it easier to bend(reduce spring rate) then why not just make it smaller? I think the issue is durability. Either the thickness of the bar doesn't like that bend, or a smaller bar is not durable enough so they went to a larger one and added more lever to it. I don't think clearance is an issue. The bar is not really in the way of anything. Here is the subframe with everything mounted out of the car. Not a great pic but there is no clearance issue that I have noticed.
#14 | |
Drives: Toyota 86
| Springs shape | gpvecchi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 11-05-2020 07:32 PM |
| {NY} BRZ SPC LCA's used 3KMI in great shape $OLD | BRZ!@# | Brakes, Suspension, Chassis | 1 | 06-26-2018 07:01 PM |
| Fender vent shape | Gunman | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-04-2016 04:29 PM |
| Headlight shape | cslntuee | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 02-28-2013 04:44 AM |
