Old 11-04-2020, 04:46 PM   #1
gpvecchi
gpvecchi's Avatar
Springs shape
Sorry guys, if you take two springs, with same wire diameter, same lenght, etc, but with different number of coils, which one will be the stiffest?
The one with more coils or the one with less?
gpvecchi is offline   Reply With Quote
Old 11-04-2020, 08:45 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
what is the point of reference here?
have you ever stretched pen springs, to shoot the cartridges into the ceiling tiles in class, or annoy the cute blonde in the front row? similar concept to your question.
the number of coils will have very little difference in stiffness, but an increasing amount of coils will drastically reduce the overall spring height, reducing the available shock stroke length.
Old 11-04-2020, 09:07 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
A straight line from point a to point b would resist deformation the most.
You'll have to divulge more succinct parameters to proceed from there.
There's barrel shaped springs so the coils can get out of each others way.
More coils will be heavier and hysteresis will make them react slower, and, and ...
... you can move the world with a lever long enough. I haven't tried this yet.
Old 11-04-2020, 09:40 PM   #4
soundman98
soundman98's Avatar
the real problem there is what one would use for a fulcrum.
Old 11-05-2020, 03:00 AM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
The longer the wire? the softer the spring. So more coils would mean longer therefore softer
gen3v8 is offline   Reply With Quote
The Following 2 Users Say Thank You to gen3v8 For This Useful Post:
gpvecchi (11-05-2020), Racecomp Engineering (11-05-2020)
Old 11-05-2020, 03:47 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
There are large count of parameters at play but just diameter/coil count/thickness of coil, shape (eg. as with progressive coils), and most importantly - material and manufacturing QA.
By just few of them known i see no way to tell except testing/measuring by yourself.
Any practical case you may need answers to this? Have pile of springs with no specs from manufacturer? Imho known quality spring manufacturers should provide specs for their products w/o need to measure yourself or playing guesswork with just few variables known. Not sure i'd wish to use springs of unknown quality and possible variance in spring rates between them due worse QA in manufacturing.
The Following 3 Users Say Thank You to churchx For This Useful Post:
gpvecchi (11-05-2020), Racecomp Engineering (11-05-2020), soundman98 (11-05-2020)
Old 11-05-2020, 04:10 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Doubling the number of coils gives half the spring rate.
Halving number of coils doubles spring rate.
K = (G * d^4) / (8 * N * D^3)
K is stiffness
G is material shear modulus
d is wire diameter
N is number of active turns or coils
D is mean spring diameter
The Following 4 Users Say Thank You to ZDan For This Useful Post:
gpvecchi (11-05-2020), Ohio Enthusiast (11-05-2020), Racecomp Engineering (11-05-2020), soundman98 (11-05-2020)
Old 11-05-2020, 08:02 AM   #8
gpvecchi
gpvecchi's Avatar
So, more coils, more soft. This is what I was looking to, thanks!
Old 11-05-2020, 10:30 AM   #9
K is stiffness
d is wire diameter
No. It is not that simple. As Dan said the number of coils is only one part of the equation. You can not simply ignore all the other required data and go by number of coils.
Old 11-05-2020, 12:59 PM   #10
norcalpb
norcalpb's Avatar
Yup, my soft STi springs have fewer coils than my stiff RCE springs.
The Following User Says Thank You to norcalpb For This Useful Post:
Tcoat (11-05-2020)
Old 11-05-2020, 04:34 PM   #11
BarryOtt
Perhaps you missed the first post:
Based on his first post, this is correct:
BarryOtt is offline   Reply With Quote
The Following User Says Thank You to BarryOtt For This Useful Post:
Old 11-05-2020, 04:45 PM   #12
gpvecchi
gpvecchi's Avatar
Yes guys, I just wanted to know how this parameter influences the stifness, I know there are a lot of other ones to consider...
Old 11-05-2020, 04:50 PM   #13
pallen
pallen's Avatar
Drives: 2017 Toyota 86
We can go deeper
pallen is offline   Reply With Quote
The Following 3 Users Say Thank You to pallen For This Useful Post:
gpvecchi (11-06-2020), soundman98 (11-05-2020), Tcoat (11-05-2020)
Old 11-05-2020, 06:22 PM   #14
Perhaps you missed the fact that there are many materials that springs are made of and that is a major part of the equation.
You can not just take two of the parts of the equation and get an answer. Not even a ball park one.
But go ahead just make shit up and run with it since it makes no difference to me.
{NY} BRZ SPC LCA's used 3KMI in great shape $OLD BRZ!@# Brakes, Suspension, Chassis 1 06-26-2018 07:01 PM
Fender vent shape Gunman Cosmetic Modification (Interior/Exterior/Lighting) 4 05-04-2016 04:29 PM
JDM Side Marker shape difference Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 11 08-29-2013 09:04 AM
Headlight shape cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 5 02-28-2013 04:44 AM
