Old 12-17-2019, 01:57 PM   #15
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
That should do it, gradually increase pressure. Watch the socket, if you see it start turning and the base of the bolt head isn't moving I would stop. Best to go to an extractor at that point.
honestly if that doesn’t work i’m gonna do an oil change through dipstick tube hole😂😂😂
SamtheKorean is offline   Reply With Quote
Old 12-17-2019, 02:07 PM   #16
Bubba's last resort.
First make sure your auto insurance is paid up, then move your car way down the driveway then heat up the area around the bolt with the torch.
humfrz is online now   Reply With Quote
gravitylover (12-20-2019), NoHaveMSG (12-17-2019)
Old 12-17-2019, 05:13 PM   #17
SamtheKorean
September
Drives: 2015 BRZ
reminds me of this meme
The Following 3 Users Say Thank You to SamtheKorean For This Useful Post:
humfrz (12-17-2019), Mr.ac (12-20-2019), soundman98 (12-17-2019)
Old 12-17-2019, 08:51 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by YamahaR86 View Post
Everyone has good suggestions already.
Remove that splash panel if you haven't for more access. I'd use big vice grips first, then hammer on the 6 point with a long breaker bar. I personally haven't used those socket extractors yet but they look promising. I did try to use the drill bit extractors for smaller bolts but that didn't work.
i've used them on my older truck a couple times for rotted out fasteners. they've always worked. but those were fasteners that were properly torqued, not over-torqued...
SamtheKorean (12-18-2019)
Old 12-18-2019, 12:17 PM   #19
highway7
Drives: FRS 2013
6 point
Then remove splash panel and use vice grips
How did you manage to round off the bolt? Unless the 12 pt wasn't on properly?
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
SamtheKorean (12-20-2019)
Old 12-20-2019, 11:45 AM   #20
gravitylover
Hammering on a steel bolt that's threaded into aluminum may turn out poorly I can picture cracking the oil pan and causing a whole other, much more expensive problem. Get the bolt extractor and be nice to it.
The Following User Says Thank You to gravitylover For This Useful Post:
Old 12-20-2019, 12:19 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The lower pan is steel.
Old 12-20-2019, 02:45 PM   #22
Sorry I missed this thread until now. I think a small pipe wrench has potential here.
Old 12-20-2019, 07:32 PM   #23
soundman98
soundman98's Avatar
Originally Posted by highway7 View Post
6 point
it could be a harbor freight 12pt, which i'm convinced are 1/32 oversized.
i don't believe i've ever successfully removed any fasteners with my 12pt harbor freight set. i've rounded most of them off... which is half the sockets i own. the other half are 6pt harbor freights...
Old 12-20-2019, 07:42 PM   #24
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I hope you've learned something here...
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
gravitylover (12-22-2019), SamtheKorean (12-20-2019)
Old 12-20-2019, 08:12 PM   #25
soundman98
soundman98's Avatar
yes. buy extra's so i have something to tide me over till i can get them warrantied!
have you priced out sockets?!? i already sold the liver and a testicle for the tool box... the matco guy said he only accepts payments now in the form of first born's. i don't have any kids, therefore, i'm not getting any new sockets.
Old 12-20-2019, 08:20 PM   #26
SamtheKorean
September
Drives: 2015 BRZ
6 point
yeah 12 points socket and wasn’t sitting properly
Old 12-20-2019, 08:23 PM   #27
SamtheKorean
September
Drives: 2015 BRZ
I finally got all the tools so tomorrow morning i’m attacking that sucka bolt. if nothing works out ill put my baby up for sale lol
Old 12-20-2019, 08:25 PM   #28
SamtheKorean
September
Drives: 2015 BRZ
that’s me tho when i’m purchasing race car parts “y’all take kidney as a payment?”
The Following User Says Thank You to SamtheKorean For This Useful Post:
soundman98 (12-20-2019)
Quick Drain Plug dholloway543 Engine, Exhaust, Transmission 29 11-14-2019 01:08 PM
Why isn't there a 2nd drain plug on the bottom of AT oil pan? FT86.ca Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-04-2017 08:40 PM
Drain plug leaking...what to do... OUGrad05 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-28-2016 02:01 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Oil Drain Plug Size jjkerr626 Engine, Exhaust, Transmission 3 11-28-2014 06:20 PM
