Drives: 2015 BMW 335i M Sport, 2004 Z06
Drain plug leaking...what to do...
Guys I finally found a car yesterday about 200 miles from my house. Went looked at it, took it for a quick test drive, everything check out great. Carfax/Autocheck look good. It was a long haul home and I noticed this morning pulling the car out a small puddle of oil under the car. At first I thought it was water or condensate from the AC.
Nope, definitely oil when I got out to look. So I put the car on stands and it appears to be coming from around the drain plug. So I'm not sure if it's been cross threaded or what? It was tight, I loosened and retightened myself (hand tight). I'm a bit annoyed because the dealership is 200 miles away, but overall it seems like a really good car. I am annoyed that after a day the drain plug seems to have an issue. Is this common or is something else amiss?? |
#2 | |
![]() Family coming in for Easter so I just need it done. |
not playing cards
Don't guess, specify and look for it on the invoice.
Oh ya, and I told the service advisor specifically, fix the leak around the drain plug even if it requires a new plug, definitely replace the gasket. He said they do the gasket/washer every change. Should be good to go in a bit.
#5 | |
A leaking drain plug isn't (or shouldn't be) a common issue. Hopefully, a new gasket will fix er up. Worst case, a new oil pan and new plug would be required. Don't listen to those old coots that will talk about ..... re-tapping and installing a larger drain plug ........ or using plumbers tape ...... or sticking a corn cob in it ....... ![]() humfrz |
Drives: 2013 SPD Black FR-S
People at the dealership just love to over or under tighten the nut, they did it to me too. I didn't even bother using my last free oil change, trust them ~0%. But other than that congratulations! Im sure you will love the car, I do two years later, just boosted about a week ago and I love it even more!
#7 | |
Yaaaaaa...............
Brings to mind the old proverb: For want of a nail the shoe was lost. For want of a shoe the horse was lost. For want of a horse the rider was lost. For want of a rider the message was lost. For want of a message the battle was lost. For want of a battle the kingdom was lost. And all for the want of a horseshoe nail. humfrz |
Just another BRZ owner
Drives: 2014 Subaru BRZ Limited MT
If you find its the plug, I suggest you get a fumoto drain valve. I have them in my daily and brz and its awesome.
2014 Dark Grey Metalic Subaru brz limited 6 MT
Follow my Instagram @sal_brz |
#10 |
Drives: 2005 Toyota Camry
| Greddy Oil Drain Plug - Leaking | Pokeguyjai | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 03-28-2026 09:56 AM |
| SOLD: Greddy Magnetic Oil Drain Plug (NJ) | zc06_kisstherain | Engine, Exhaust, Bolt-Ons | 8 | 05-15-2016 09:07 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| Best magnetic drain plug? | FR-Sizzle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 09-28-2015 01:07 PM |
| Oil Drain Plug Size | jjkerr626 | Engine, Exhaust, Transmission | 3 | 11-28-2014 06:20 PM |
