| View Poll Results: Is it a good idea? | |||
| Yes |
16 | 84.21% |
| No |
3 | 15.79% |
| Voters: 19. You may not vote on this poll | |||
Software Hobbiest
Drives: 2015 FRS
Quick Drain Plug
https://www.killerbmotorsport.net/fu...-1-5.html.html
I found this quick drain plug for the FA20 and at first though it would be a good idea. After realizing it has no magnet im not so sure anymore. Do you think its a good idea or not? |
Drives: 2014 FRS Ultramarine
I've had that exact same plug installed for about 40,000 miles now. Never had any issues with it and I drive it on track, in the winter, etc. I don't believe the stock plugs are magnetic so not sure what the benefits would be there?
Sent from my ONEPLUS A5010 using Tapatalk |
Drives: 2016 Scion FRS
While this is admittedly an extremely unlikely freak incident....
I once autocrossed a car with one of these. I hit a cone that remained wedged under the car. When I hit the brakes to stop the car, the cone opened up the fumoto valve, draining all the oil from a running car. |
| The Following User Says Thank You to steverife For This Useful Post: | dholloway543 (11-13-2019) |
Drives: Bone stock
It has a black thingy lol to keep it from opening.
Sent from my SM-N960U using Tapatalk |
Drives: Subaru BRZ
Well, they're called 'KillerBMotors" hopefully nothing to do with the quick oil plug thingy..
| The Following 2 Users Say Thank You to JD001 For This Useful Post: | new2subaru (11-13-2019), Spuds (11-13-2019) |
not playing cards
I think that the more important questions are:
1. Why consider a magnet? 2. Why consider a magnet on a valve? I'm asking leading questions to gauge interest in the conversation.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (11-13-2019) |
Drives: 2015 BRZ WRB
I installed Fumotos on several cars in the last couple of yrs, love them.
That autocross thing got me worried but I have the black thingy. I agree, why magnet? You do have an oil filter, right? |
Software Hobbiest
Drives: 2015 FRS
Magnet because the oil goes from the oil pan through the oil pump into the oil filter. Ie the pump see's all of the garbage.
I think im going to just mount an external magnet and run the quick drain plug. |
#10 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The way forward. Makes oil changes simples.
Magnet valve? Yeah, no. If you absolutely need magnets (for whatevers) put some on the outside of the filter after installation. Braces and belt.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | Ultramaroon (11-13-2019) |
#12 | |
It sorta works like this: (dang, I can't remember if I took my meds this morning or not - )humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | NoHaveMSG (11-13-2019), soundman98 (11-13-2019) |
#13 |
Software Hobbiest
Drives: 2015 FRS
The point of the magnet is to catch ferrous materials floating in the oil. -_-
be it, it is pretty funny how you guys describe it |
| The Following User Says Thank You to dholloway543 For This Useful Post: | humfrz (11-13-2019) |
#14 |
I haven't had any problems with my Fumoto valves. I've got one on this car and one on my wife's GTI. Makes oil changes really simple and quick. Just be careful if you hit any debris or scrape your undercarriage.
2022 BRZ Build 2013 FR-S Build |
| Why isn't there a 2nd drain plug on the bottom of AT oil pan? | FT86.ca | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 03-04-2017 08:40 PM |
| Drain plug leaking...what to do... | OUGrad05 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-28-2016 02:01 PM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| Best magnetic drain plug? | FR-Sizzle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 09-28-2015 01:07 PM |
| Oil Drain Plug Size | jjkerr626 | Engine, Exhaust, Transmission | 3 | 11-28-2014 06:20 PM |
