Old 11-27-2014, 09:59 AM   #1
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
Oil Drain Plug Size
Hello does anyone know how many millimetres the drain plug is. I am trying to replace it with a Fumoto valve but can't find any info on size anywhere. Thank you.
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 11-27-2014, 11:33 AM   #2
s2d4
s2d4's Avatar
F108 variants
Old 11-27-2014, 03:41 PM   #3
jjkerr626
jjkerr626's Avatar
What is F108 Variants, sorry for my ignorance. Thank you.
Old 11-28-2014, 06:20 PM   #4
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
M16x1.5, the Fumuto F108 (no nipple, F108S (short with detachable nipple), or F108N (long nipple). I don't recommend the N due to low ground clearance, but the regular and S are fine. I have an S though I never use the detachable piece anyway.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Greddy Oil Drain Plug - Leaking Pokeguyjai Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 03-28-2026 09:56 AM
Subaru or Toyota drain plug? yayforaddison Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 05-06-2020 10:59 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Help! - slow leak from oil drain plug amram Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 05-28-2014 02:42 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 06:04 PM
