Old 06-07-2019, 10:48 PM   #15
Well not sure what can be the issue(s)
Worse case blown head gasket(s)
Bad radiator fan, or just not enough coolant
Bad water pump?
You can pressure test the radiator, and do a leak down test.
That's all I got.
WHAT! No civics in stock -
Old 06-08-2019, 12:23 PM   #16
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Without temp readings on the gauge, you don't know what temp your car was at. As others have mentioned, you need a scanner that can read engine coolant temps to be able to determine if you really have an issue.
That being said, with the turbo charger, you've added a heat source to your cooling (and oiling) system. If you did not make any changes to the heat transfer capacity of your cooling system you will run into overheating issues under certain circumstances.
With the A/C on, the air that passes over the condenser becomes warmer and then when it gets to the radiator has less capacity to transfer heat. So in the case of running with a turbo and a/c on you have more heat in your cooling system and less ability to transfer that heat out.
Assuming you have no leaks, swapping a radiator out for a direct replacement part is not going to help you. If you get a larger one, it will help by increasing heat transfer capability.
Changing your thermostat to a lower temperature will also not help you unless you want your car to run at a cooler temp all the time. If you generate more heat in your cooling system than the system can remove the lower temp thermostat is only going to delay your overheating issue.
All in all, I would do as others have said. Ensure everything is functioning as designed. If it is and you still have overheating issues I would start with a more robust radiator that can transfer more heat.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following 2 Users Say Thank You to ActionMaxon For This Useful Post:
humfrz (06-08-2019), j_ros94 (06-08-2019)
Old 06-08-2019, 12:27 PM   #17
j_ros94
Drives: 2017 Subaru BRZ
So far everything is running well. No visible leaks, fan turns on when ac is on. I just got a coolant flush so im assuming theres no air bubble (might try to bleed again). But thank you so much for this
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 06-08-2019, 12:37 PM   #18
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
And if you still have issues after making sure there's no air in the radiator, you can buy an air/oil cooler.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Old 06-08-2019, 01:49 PM   #19
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
That stock gauge is so inaccurate.
Trueweltall is offline   Reply With Quote
Old 06-08-2019, 03:01 PM   #20
Overeating
That's how I read the thread title every time.
Old 06-08-2019, 03:37 PM   #21
Is not - that's the way it's designed, so as not to alarm people who "can't handle the truth" -
Ultramaroon (06-08-2019)
Old 06-08-2019, 03:42 PM   #22
I got the picture -
Old 06-08-2019, 05:40 PM   #23
You're damn right I ordered a new rad!
Old 06-08-2019, 06:11 PM   #24
I hope the hell you ordered a big enough one -
Old 06-08-2019, 09:30 PM   #25
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sold my last two SI's
Its always amazing how much of a chump people are.
I sold the Si for type R money. No one ever check the engine they all want the type R badge.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (06-08-2019)
Old 06-08-2019, 10:24 PM   #26
So, back-in-the-day, did you do this to turn odometers back or did you hook the cable up to a drill and let it run backwards all night? - fess up now -
Old 06-09-2019, 12:47 AM   #27
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Piff that's the ghetto con mans way.
We had a guy in a salvage yard that would pull low mile wrecks's vins and gauge clusters. We just did the swap before logging it into the DMV database.
Drilling out the rivets is not as hard as it seems. Hard part was windshield removal
humfrz (06-09-2019)
Old 06-09-2019, 12:59 AM   #28
WOW! What a deal, considering that civic on your lot only has 1,235 actual miles on it -
Brakes Overheating BierMeister Issues | Warranty | Recalls / TSB 29 02-25-2019 01:44 PM
Any solutions to overheating coilpacks? Turbo Tracking / Autocross / HPDE / Drifting 11 12-21-2018 11:36 PM
Intermittent overheating on one brake Yousend Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-24-2018 05:17 PM
whole lot of weirdness/possible overheating shaynek Issues | Warranty | Recalls / TSB 7 08-01-2018 06:56 PM
BRZ overheating Notso BRZ First-Gen (2012+) — General Topics 67 06-25-2016 12:01 PM
