Old 06-01-2016, 05:54 PM   #1
Notso
Drives: Subaru BRZ
BRZ overheating
hello all, i'm hoping someone can help. I had my brz parked for a year (license suspension) when i finally got it back i pulled my car out and there was a huge dried puddle of coolant i'm assuming. I went to a shop to have my oil changed, told them what was happening and see if they could diagnose the problem. They said I have a small coolant leak, they tested all my fans etc everything is fine. they said keep the coolant topped off and it should be fine. no auto shop can or is willing to get it on a car jack because i've lowered it. so i kept the coolant levels topped off and it's still overheating. so i thought it might be the thermostat. I took out the thermostat (which is a total bitch to get to) tested it and it's fine. resembled everything, cleaned my skid plate so i could see if there was additional leaking. filled it with subaru's special expensive blue coolant etc... just got back from driving it about 10 miles, overheating again. checked the skidplate and there is the blue coolant leaking on the driver side looks like it's right under the thermostat housing. super frustrating, hoping i can get some advise. hope it's not the head gasket thanks for any responses
Notso is offline   Reply With Quote
Old 06-01-2016, 06:00 PM   #2
ryoma
ryoma's Avatar
have you checked the rubber hoses that lead to the radiator and engine for cracks?
Old 06-01-2016, 06:07 PM   #3
Notso
Drives: Subaru BRZ
i have, i did a flush, filled the radiator with water waited an hour too see if there was any leaks before i put the skidplate back on
Old 06-01-2016, 08:39 PM   #4
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
$10 says it's a weeping waterpump
86kahl is offline   Reply With Quote
Old 06-01-2016, 09:23 PM   #5
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
Man auto shops won't put your car on a lift cause it's lowered? That's obnoxious.
I would also guess the water pump is faulty. How many miles are on your BRZ? I feel like that could be a warranty issue.
Sent from my Nexus 6P using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
Old 06-01-2016, 10:53 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
How is the coolant overheating being diagnosed?
Could be air trapped in the system. May just need a better/more complete bleed...
-alex
Old 06-01-2016, 11:24 PM   #7
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
My first supra would overheat and everything checked out perfect.
No leaks and system pressure tested fine.
Until we decided to replace the water pump just because it was the last thing that it could be.
The pump impeller was almost completely eroded away and nothing left but a nub.
It was from using the wrong coolant. It dissolved the impeller.
I think the new pumps have plastic or ceramic impellers, but I am not sure.
Either that or your system has an air bubble from the slow leak and you need to purge it.
Just having a slow leak (by itself) will not cause the car to overheat
justatroll is offline   Reply With Quote
Old 06-02-2016, 12:52 AM   #8
Notso
Drives: Subaru BRZ
Yeah it is obnoxious, Subaru won't even do it. around 30k hopefully it's just a water pump
Old 06-02-2016, 12:53 AM   #9
Notso
Drives: Subaru BRZ
-alex
maybe, but what would cause the leaking?
Old 06-02-2016, 01:02 AM   #10
Notso
Drives: Subaru BRZ
this could be it, I bought it used not from a subaru dealer. previous owner could have put wrong coolant in, it sat for a year and eventually dissolved something in the water pump????
Old 06-02-2016, 01:07 AM   #11
Notso
Drives: Subaru BRZ
thanks everyone for your replies, appreciate it... no one around here seems to know anything, including subaru
Old 06-02-2016, 11:12 AM   #12
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
because nobody experienced like this or yet.
if everything checked fine, then water pump could be issue like someone said
Old 06-02-2016, 12:59 PM   #13
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
FYI in the future I'd strongly urge not letting a car sit for an entire year unused. That's hell on the car. I understand your license was suspended but ask a friend to drive it around every once in a while (if that ever happens again).
I'd also recommend lifting the car a little bit; otherwise it sounds like no shop will ever work on your car in the future.
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 06-02-2016, 01:33 PM   #14
mav1178
mav1178's Avatar
Wow... you didn't even wait for a reply.
Again: I ask why you think it's overheating. I am not speculating on leak source, I am asking why you think it's overheating and how it is diagnosed. If you can't describe how you reached the overheating conclusion, you aren't telling us the whole story and no one can help you, not even Subaru.
Leaks in the coolant system are from any of these sources:
- heater core
- radiator
- hoses
- leaking head gasket
- water pump
- radiator cap
Overheating is from any of the following:
- actual overheating
- air trapped in system
- bad radiator cap
- leaks
- faulty coolant temp sensors
If you are having an overheating issue but you can run the engine with no visible leaks, then you simply need to bleed the system better.
Best $25 you'll ever spend:
[ame="http://www.amazon.com/Lisle-24680-Spill-Free-Funnel/dp/B00A6AS6LY/"]Amazon.com: Lisle 24680 Spill-Free Funnel: Automotive[/ame]
-alex
Overheating of central part of cabin between seats jorgelucho Issues | Warranty | Recalls / TSB 2 10-06-2014 03:48 PM
Massive Overheating Incident mitosis Issues | Warranty | Recalls / TSB 26 11-18-2013 07:12 AM
