Old 02-21-2019, 10:15 PM   #1
BierMeister
Drives: 2017 BRZ PP CWP
Brakes Overheating
This winter has been a bit of a disappointment in NJ, and I've only had 2 opportunities to do some sliding in the snow. Now I'm trying to figure out why my front passenger side brakes were cooked after each time. This led to dangerous rides home where the car was pulling to the left whenever I hit the brakes. I could clearly feel the heat coming off of the front passenger set when I got home.
So my theory is that even with the traction control and stability control set to "off" (holding the "off" button for 5 seconds) the stability control was actuating the front passenger brakes in an effort to correct the slide. It just so happens that I was drifting to the left 90% of the time.
What do you guys think? Could the stability control do something like this? Or are my pads/rotors/calipers defective? I might have a Subaru tech look into it when I go for an oil change.
BierMeister is offline   Reply With Quote
Old 02-21-2019, 10:24 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The long press does not disable the electronic brakeforce distribution and E-diff. The EBD is likely interfering, though I have not heard of it doing it to that degree. Youtube "pedal dance" and try that next time.
Old 02-21-2019, 10:37 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Caliper sticking could cause this. I drive around in snowstorms using the long press and get no interference.
Old 02-21-2019, 11:32 PM   #4
humfrz
I'd suggest you take your car in for a brake inspection right away and not wait for your next oil change.
humfrz
Old 02-22-2019, 02:28 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
My money is on a stuck caliper. Could be a guide pin, or the piston. Either way common problem in places with lots of rain/snow/or salted roads.
Simple fix. Any auto mechanic can fix it.
Old 02-22-2019, 10:20 AM   #6
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
For 17+BRZs with a manual transmission the e-diff is disabled by a long press, the pedal dance is not necessary.
NCtoBRZ is offline   Reply With Quote
The Following 4 Users Say Thank You to NCtoBRZ For This Useful Post:
Interlocker (02-22-2019), NoHaveMSG (02-22-2019), TRAKRAVN (02-22-2019), Tristor (02-23-2019)
Old 02-22-2019, 11:09 AM   #7
gravitylover
^^ I wonder if that's something that can be programmed into the older cars.
Old 02-22-2019, 11:38 AM   #8
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Would the brake LSD still activate with a clutch type LSD installed, or would there not be enough of a wheel speed difference to activate it?
TRAKRAVN is offline   Reply With Quote
Old 02-22-2019, 07:36 PM   #9
BierMeister
So I guess this disproves my original theory. I plan on bringing it to the dealer next week but I'm afraid they won't discover anything. My pads appear to be worn evenly and the brakes haven't been heating unevenly either. It drove just fine over the last few days.
This has only happened the 2 times that I did donuts in the snow.
Old 02-23-2019, 12:08 AM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It doesn't just look at wheel speed difference there's accelerometer type sensors it takes into account as well. It would still activate I believe.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
TRAKRAVN (02-23-2019)
Old 02-23-2019, 12:13 AM   #11
FRSBRZGT86FAN
Make sure they check everything brake related as well as suspension related, older fluid may over heat. Also make sure the tire pressures were equal before you do any drifting in the snow type stuff. It's very odd for a 2017 to have brake issues....
Old 02-23-2019, 10:23 AM   #12
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
It's a '17, is this it's 2nd winter?
I'm no expert in US weather, but you might be having some brake seizing issues if they've never been dismantled, cleaned and had brake lube applied appropriately. Winter is ROUGH, and road abrasives and salt are ROUGH on disc brakes. Here in Quebec, most disc brake pads that have been lubed will seize solid in the rack in about a year in a half if they're left alone. Considering most cars leave the dealer lots with completely dry brakes, it wouldn't be a surprise to see them starting to jam within a year after they're put in service.
It may not be completely stuck and work in normal driving, but if more heat is being put into them like during "spirited" driving, it's possible for the pads to expand and bind, causing more expansion and binding and more expansion and binding.
Old 02-23-2019, 11:40 AM   #13
BierMeister
I bought the car new in April of last year so this would be its first winter. Like I said, there hasn't been much snow in nj this winter.
Old 02-23-2019, 11:51 AM   #14
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Not sure why there is so much discussion about the brake LSD being the cause when he said it was the FRONT brakes that were overheating...?
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Ultramaroon (02-23-2019)
Any solutions to overheating coilpacks? Turbo Tracking / Autocross / HPDE / Drifting 11 12-21-2018 11:36 PM
whole lot of weirdness/possible overheating shaynek Issues | Warranty | Recalls / TSB 7 08-01-2018 06:56 PM
Overheating stick shift sj30jet Engine, Exhaust, Transmission 8 06-12-2017 01:03 PM
BRZ overheating Notso BRZ First-Gen (2012+) — General Topics 67 06-25-2016 12:01 PM
Massive Overheating Incident mitosis Issues | Warranty | Recalls / TSB 26 11-18-2013 07:12 AM
